I have run this code to connect the esp32 to the wifi network the result is this msg on the serial monitor
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load:0x40078000,len:9564
ho 0 tail 12 room 4
load:0x40080400,len:6320
entry 0x400806a8
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4013236c PS : 0x00060630 A0 : 0x80130239 A1 : 0x3ffb54a0
A2 : 0x00000001 A3 : 0x3ffc7050 A4 : 0x00100000 A5 : 0x0d13007f
A6 : 0x00ad7f98 A7 : 0xfffcffff A8 : 0x81041322 A9 : 0x00000006
A10 : 0x00000001 A11 : 0x3ffbf720 A12 : 0x0000003d A13 : 0x3ffc7061
A14 : 0x3ffb5460 A15 : 0x3ffc7050 SAR : 0x00000007 EXCCAUSE: 0x0000001c
EXCVADDR: 0x81041322 LBEG : 0x4013236c LEND : 0x40132374 LCOUNT : 0x00000005
Code:
#include <WiFi.h>
const char* ssid = "PPPP";
const char* password = "PPPP";
WiFi .begin( ssid, password );
Serial .print("connecting to WiFi");
Serial.print(".");
delay(500);
Serial.println("\nConnected to the WiFi network");
Serial.println("IP address: ");
if ((WiFi.status() == WL_CONNECTED)) //check the current connection stat
Serial.println("you can try to ping me");
delay(5000);
else
Serial.println("connection lost");
delay(5000);
please help me solve this problem
Esp32 & arduino IDE (serial monitor fail)
Re: Esp32 & arduino IDE (serial monitor fail)
The bootloader is crashing before it can load your sketch.
It may be a hardware issue of some kind (what ESP32 dev board are you using?) or it might be a configuration issue.
I notice from the log ("clk div: 1") that the SPI Flash clock is set to 80MHz. Try changing it to 40MHz or 20MHz in the board configuration (under the Tools menu) and see if it can boot successfully after re-uploading.
Angus
Angus
Users browsing this forum: No registered users and 50 guests
