I've got an ESP32 WROOM-32 module but I'm slightly confused about which settings to use in the Arduino IDE for this module (ESP32 Dev Board).
My code had previously been running on the ESP32 WROOM, but I have to choose a large app partition with no OTA because the code was so large. The WROOM-32 module has much more memory and I want to incorporate OTA functionality in my code. What menu settings should I select in Arduino?
ESP32 WROOM-32
Re: ESP32 WROOM-32
Humm.
So you had an ESP32 and you replaced it with a ESP32 WROOM and you now expect to get more memory available but a ESP32 DEV is a ESP32 WROOM.
If you want more ram from an ESP32 you'd want to go with a ESP32 WROVER. Many WROVER's come with 8+ MB ram. Using the Arduino IDE with a Wrover you can access about 4MB, which is called HiMem of the WROVER's ram, bank switching (in the Arduino IDE) does not work, yet.
Now when you go to use that extra RAM it is great for storing large data thingies into. I tend to put most of my variables into the HiMem area.
I use the libraries:
#include "sdkconfig.h"
and
extern "C"
#include <esp_himem.h>
to get access to the extra ram.
I use log_i("Total PSRAM: %d", ESP.getPsramSize()); and log_i("Free PSRAM: %d", ESP.getFreePsram()); to get the extra ram size use / avaialibility.
Here are a few examples of using the WROVERS ram:
You may want to refer to the ESP32 API https://docs.espressif.com/projects/esp ... himem.html, The himem allocation API for more information.
and
extern "C"
int *ptr, *ptr1;
int n, n1, i, sum = 0;
float *ptrFloat;
// Get the number of elements for the array
n = 10;
n1 = 20;
log_i("Number of elements ptr: %d", n);
log_i("Number of elements ptr1: %d", n1);
log_i("Number of elements ptr1: %d\n", n1);
// Dynamically allocate memory using malloc()
// ptr = (int*)ps_malloc(n * sizeof(int)); //works
ptr = (int*)ps_calloc( n, sizeof(int) ); // works
ptr1 = (int*)ps_calloc( n1, sizeof(int) ); // works
// Check if the memory has been successfully
// allocated in ps_ram
ptrFloat = (float*)ps_calloc( n, sizeof(float) ); // works
if (ptr == NULL) {
log_i(" ptr memory not allocated.\n");
exit(0);
if (ptr1 == NULL)
log_i("ptr1 memory not allocated.\n");
exit(0);
else
// Memory has been successfully allocated
// log_i("ps_ram memory successfully allocated using ps_calloc.");
// put elements into ps_ram array
for (i = 0; i < n; ++i)
ptr[i] = i + 1;
for (i = 0; i < n1; ++i)
ptr1[i] = i + 2;
ptrFloat[i] = (float)i + 1.06555f;
// Print the elements of the array
log_i("The elements of the ptr array are: ");
for (i = 0; i < n; ++i) {
log_i("%d, ", ptr[i]);
log_i("The elements of the ptr1 array are: ");
for (i = 0; i < n1; ++i) {
log_i("%d, ", ptr1[i]);
log_i("The elements of the ptrFloat array are: ");
log_i("%f, ", ptrFloat[i]);
// put a structure into psram. Works.
struct stuTime *ptrStuTime;
log_i("size of structure: %d", sizeof(struct stuTime) );
ptrStuTime = (struct stuTime *)ps_malloc(sizeof(struct stuTime));
log_i("Free PSRAM after structure: %d", ESP.getFreePsram());
ptrStuTime->iSeconds = 10;
ptrStuTime->iMinutes = 60;
ptrStuTime->iHours = 100;
log_i("Seconds: %d Minutes: %d Hours: %d", ptrStuTime->iSeconds, ptrStuTime->iMinutes, ptrStuTime->iHours );
free(ptr);
free(ptr1);
free(ptrStuTime);
// works
log_i("Free PSRAM before String: %d", ESP.getFreePsram());
char *str;
char OneChar = 'a';
char TwoChar = 'b';
char ThreeChar = 'c';
str = (char *)ps_calloc(300, sizeof(char) );
log_i("Free PSRAM after String: %d", ESP.getFreePsram());
// concantenate one char variable to end of char array to the str
strncat( str, &OneChar, 1 ); //works
strncat( str, &TwoChar, 1 );
strncat( str, &ThreeChar, 1 );
//*(str+0) = 'G'; // works
//*(str+1) = 'f';
//*(str+2) = 'G';
//*(str+3) = '\0';
log_i("%s", str );
free(str);
Re: ESP32 WROOM-32
My bad - I wasn't clear in my explanation (and I think the ESP32 part naming scheme sucks)
I was using an ESP32 WROOM with 32Mbits flash, on my own PCB, programmed with an FTDI adapter, using the ESP32 dev module option on the IDE.
I have now switched to the ESP32 WROOM with 128Mbits flash, same PCB and setup. The IDE has an option (under the ESPre Dev board) for 128Mbits, but I'm not certain which, if any, of the partition options are suitable. My code compiles to 1396682 bytes, so there is plenty of flash spare on the 128Mbit device. It uses 62308 bytes of dynamic memory (19%)
My guess is that I should use the 16M - 3M APP, 9M FATFS option (as it leaves me with some room for more code)
Is this right?
Is this right?
Re: ESP32 WROOM-32
Which partition you select is up to you based upon your applications requirements.
Re: ESP32 WROOM-32
Yes, the partition depends on application requirements, I know, that is why I explained my requirements and asked for help on this support forum to make sure I have understood what the partition options actually mean so I select the correct one.
I think I understand it now - The option I have chosen gives me 3MB app, 9Mb file system and so presumably the last 4MB of the 16MB memory is a partition for the OTA update system.
Users browsing this forum: Bing [Bot], Google [Bot] and 46 guests
