MQTT: Wildcard support
arunvtec
Postby arunvtec » Tue Nov 19, 2019 10:40 am
Does the ESP-MQTT support wildcard in the MQTT topic? Is there an example on this?
I published the topic -
/multisensor/device-ID/measurements/temperature/GET
and it works fine.
But with wildcard in the topic
/multisensor/+/measurements/temperature/GET
, there is no response. 'mqtt_event_handler' is never called.
Thanks,
Arun
ESP-Marius
Re: MQTT: Wildcard support
Postby ESP-Marius » Wed Nov 20, 2019 8:40 am
Which version are you running (IDF and MQTT)?
It worked fine when I tested it right now with the master branch and a local Mosquitto broker.
Subscribing to
/topic/+/esp32
and then publishing to
 /topic/qos0/esp32
 /topic/qos1/esp32
/topic/qos2/esp32
gives me the expected result. I receive the data from all the published messages.
Could it be that your broker doesn't support wildcards?
tommeyers
Postby tommeyers » Wed Nov 20, 2019 4:36 pm
I have a feeling that the OP is publishing a wildcard not subscribing with a wildcard. OP what do you say. Sorry if I am wrong.
IT Professional, Maker
Santiago, Dominican Republic
ESP-Marius
Postby ESP-Marius » Thu Nov 21, 2019 12:50 am
Re-reading the question I see that you are probably right.
OP: if you are trying to publish with a wildcard then the answer is that this is not a part of the MQTT spec.
It says that:
The Topic Name in the PUBLISH Packet MUST NOT contain wildcard characters
Although technically there should be nothing in the esp MQTT client preventing you from publishing to an invalid topic, we don't do any checks on the content of the topic, but a well-behaving broker will probably close the connection.
tommeyers
Postby tommeyers » Fri Nov 22, 2019 9:21 pm
One other suggestion:
My MQTT broker (mosquitto) gives me some tools for debug and monitor:
I can start the broker with verbose logging and see all kinds of events
There is a generic subscriber
There is a generic publisher.
Good tools for an MQTT developer.
Tom Meyers
Users browsing this forum: No registered users and 107 guests
