Using I2S event queue or Task queue for passing adc values from buffer.
zekageri
Postby zekageri » Mon Oct 28, 2019 2:34 pm
I can not find any reliable solution for the implementation of the I2S event queues on the Arduino framework.
Currently i'am measuring a 4khz signal from a signal generator with the I2S adc via dma.
The data goes into a buffer on a task and i read that buffer from an other task.
The problem is that i think some data get lost because the other task reads the data from the buffer even when the reader does not finished.
My code right now:
static void loop0(void * pvParameters){
  for( ;; ){
        Sampling();                               // RETRIVE DATA FROM DMA BUFFER
static const inline void To_the_Stars(){
  if(millis() - Start_Millis >= 1000){
    Start_Millis = millis();
    for(int i = 0;i<NUM_SAMPLES;i++){
      Send_Data_to_Plot(i2s_read_buff[i]); // RETRIVE DATA FROM i2s_read_buff FOR CALCULATION AND VISUALIZATION
I'am sampling with 144444hz right now, and the readed data looks like this on the web:
Képernyőfelvétel (34).png (1.05 MiB) Viewed 2776 times
Képernyőfelvétel (33).png (1.04 MiB) Viewed 2776 times
Képernyőfelvétel (32).png (1.04 MiB) Viewed 2776 times
Users browsing this forum: No registered users and 71 guests
