digitalWrite(TRIGGER_PIN, HIGH); won't work. Pin always returns 0
GeorgeFlorian1
Postby GeorgeFlorian1 » Thu Oct 24, 2019 1:04 pm
Hello !
I am trying to use a GPIO from the ESP32-EVB. I have tried using GPIO 21 and 23 and this simple code:
  #define TRIGGER_PIN 21
  // #define TRIGGER_PIN 23
  pinMode(TRIGGER_PIN, INPUT_PULLUP);
  Serial.println(digitalRead(TRIGGER_PIN));
Serial.println(digitalRead(TRIGGER_PIN)); will always return 0 no matter what.
I have also tried the same thing on an ESP32 DevKitV4 and on this one, Serial.println(digitalRead(TRIGGER_PIN)); returns 1 and hooking it up to GND returns 0, which is the normal behavior.
What is the difference between the two boards ?
I believe that the ESP32 DevKitV4 has an internal resistor and the ESP32-EVB does not. And I think I need to add a resistor there somewhere. And what value should the resistor have ?
What do you think ?
EDIT
I have literally put a 10k resistor from +5V to the pin and it still returns 0.
idahowalker
Re: digitalWrite(TRIGGER_PIN, HIGH); won't work. Pin always returns 0
Postby idahowalker » Thu Oct 24, 2019 2:03 pm
What does https://www.olimex.com/Products/IoT/ESP ... e-hardware say about their board issue?
You may find that those pins may be used for something else:
http://esp32.de/ESP32-EVB-REV-B/ESP32_EVB_REV-B.jpg
GeorgeFlorian1
Postby GeorgeFlorian1 » Thu Oct 24, 2019 2:08 pm
What is their board issue ? You're telling me to ask on their forum ?
I've also been looking at the schematics and I have no idea what pin to use. They are all occupied...
idahowalker
Postby idahowalker » Thu Oct 24, 2019 10:29 pm
I am suggesting that you ask on the builder of the board forum.
Users browsing this forum: No registered users and 36 guests
