Rewriting code for universel 3 variable bluetooth connection
sigrun
Postby sigrun » Sun Oct 13, 2019 8:09 pm
Dear forum
i am quite new in ESP32 world, have bought a "Learn ESP 32 book" from Random nerd tutorials. but i need a more general purpose
Bluetooth than the included BLE -> DHT -> OLED tutorial.
So far i have rewritten the the code, to get rid of the DHT## in the Program. it worked down to the OLD line
  BLEService *dhtService = pServer->createService(SERVICE_UUID);
Which i have changed to
  BLEService *bilservice = pServer->createService(SERVICE_UUID);
Of cause it did not work, while dhtService are defined else where, and properly are a complex in it self
but what do i have to do to get the program working?
i have printed all libraries, but have a lot of troubles in reading them
full program attached, i have divided the program in tree parts it is the middle part which is of interest
  Rui Santos
  Complete project details at http://randomnerdtutorials.com
  Alle variable i forhold til de tre bluetooth værdier tempC tempF og Humidity er ændret
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include "DHT.h"
//Default Temperature is in Celsius
//Comment the next line for Temperature in Fahrenheit
#define temperatureCelsius
//BLE server name
#define bleServerName "dhtESP32"
// Uncomment one of the lines below for whatever DHT sensor type you're using!
#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
//#define DHTTYPE DHT22   // DHT 22  (AM230
2), AM2321
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "91bad492-b950-4226-aa2b-4ede9fa42f59"
#ifdef temperatureCelsius
  BLECharacteristic Avar("cba1d466-344c-4be3-ab3f-189f80dd7518", BLECharacteristic::PROPERTY_NOTIFY);
  BLEDescriptor LeftRight(BLEUUID((uint16_t)0x2902));
#else
  BLECharacteristic Bvar("f78ebbff-c8b7-4107-93de-889a6a06d408", BLECharacteristic::PROPERTY_NOTIFY);
  BLEDescriptor Hastighed(BLEUUID((uint16_t)0x2901));
#endif
BLECharacteristic Flag("ca73b3ba-39f6-4ab3-91ae-186dc9577d99", BLECharacteristic::PROPERTY_NOTIFY);
BLEDescriptor FlagReg(BLEUUID((uint16_t)0x2903));
// DHT Sensor
const int DHTPin = 14;
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
bool deviceConnected = false;
BLEService *bilservice;
//Setup callbacks onConnect and onDisconnect
class MyServerCallbacks: public BLEServerCallbacks {
  void onConnect(BLEServer* pServer) {
    deviceConnected = true;
  void onDisconnect(BLEServer* pServer) {
  // Start DHT sensor
  dht.begin();
  // Start serial communication
Code i think is in trouble
  // Create the BLE Device
  BLEDevice::init(bleServerName);
  // Create the BLE Server
  BLEServer *pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  // Create the BLE Service
  // Create BLE Characteristics and Create a BLE Descriptor
  // Descriptor bluetooth.com/specifications/gatt/viewer?
  // attributeXmlFile=org.bluetooth.descriptor.gatt.client_characteristic_configuration.xml
    bilService->addCharacteristic(&Avar);
    LeftRight.setValue("Højre/Venstre");
    Avar.addDescriptor(new BLE2902());
  #else
    bilService->addCharacteristic(&Bvar);
    Hastighed.setValue("Hastighed");
    Bvar.addDescriptor(new BLE2902());
  #endif
    bilService->addCharacteristic(&Flag);
    FlagReg.setValue("Flag indhold");
    Flag.addDescriptor(new BLE2902());
  // Start the service
   * dhtService->start();
  bilService->start();
  // Start advertising
  pServer->getAdvertising()->start();
  Serial.println("Waiting a client connection to notify...");
  if (deviceConnected) {
    // Read temperature as Celsius (the default)
    float t = analogRead(32);
    // Read temperature as Fahrenheit (isFahrenheit = true)
    float f = analogRead(33);
    // Read humidity
    float h = analogRead(34);
    // Check if any reads failed and exit early (to try again).
    if (isnan(h) || isnan(t) || isnan(f)) {
      Serial.println("Failed to read from DHT sensor!");
      return;
    //Notify temperature reading from DHT sensor
      static char temperatureCTemp[7];
      dtostrf(t, 6, 2, temperatureCTemp);
      //Set temperature Characteristic value and notify connected client
      Avar.setValue(temperatureCTemp);
      Avar.notify();
      Serial.print("Temperature Celsius: ");
      Serial.print(t);
      Serial.print(" *C");
    #else
      static char temperatureFTemp[7];
      dtostrf(f, 6, 2, temperatureFTemp);
      Bvar.setValue(temperatureFTemp);
      Bvar.notify();
      Serial.print("Temperature Fahrenheit: ");
      Serial.print(f);
      Serial.print(" *F");
    #endif
    //Notify humidity reading from DHT
    static char humidityTemp[7];
    dtostrf(h, 6, 2, humidityTemp);
    //Set humidity Characteristic value and notify connected client
    Flag.setValue(humidityTemp);
    Flag.notify();
    Serial.print(" - Humidity: ");
    Serial.print(h);
    Serial.println(" %");
    delay(10000);
chegewara
Re: Rewriting code for universel 3 variable bluetooth connection
Postby chegewara » Mon Oct 14, 2019 2:01 pm
Thats nice you shared so many code with us, but without info what error logs you get all this tells us nothing.
Try this:
https://github.com/me-no-dev/EspExceptionDecoder
sigrun
Postby sigrun » Thu Oct 17, 2019 10:58 am
dear chegewara
There was a little busy the last few days
When i send the topic some days ago i had a error bilservice is not defined
but when i compiled the program yesterday there were no error codes the program just
compiled and flashed the program to the ESP
i will try to install the library traiser to day
Users browsing this forum: Google [Bot] and 68 guests
