- Hi for all. I am fresh member. I would like to ask you something about flash encryption. I tried to apply flash encryption and enabled it from menuconfig. However I got an error like that: esptool write_flash: error: argument <address> <filename>: Detected overlap at address: 0x8000 for file: C:/msys32/home/xxx/esp/esp-idf/examples/security/flash_encryption/build/partitions_singleapp.bin
- make: *** [/home/xxx/esp/esp-idf/components/esptool_py/Makefile.projbuild:92: flash] Error 2
- What it could be? Also, I could not find any tutorial or appliance of flash encryption on internet. If you know, can you share with me? It is a little bit hard for me trying understand docs of espressif. Thanks for all.
Flash encryption
Flash encryption
Re: Flash encryption
Your bootloader is overlapping the partition table. Either reduce the log level for the bootloader or relocate the partition table if your version of IDF allows it.
Users browsing this forum: Baidu [Spider], g3_san and 92 guests
