WiFi not working after flashing several times Sparkfun-Thing ESP32
preetam
Postby preetam » Wed Feb 22, 2017 9:55 am
I have flashed two ESP32s several times. In one of the ESP32 WiFi has stopped working and below is the log. I did try to connect to different AP, Same issue still exists.
I (1180) wifi: n:6 0, o:1 0, ap:255 255, sta:6 0, prof:1
I (1830) wifi: state: init -> auth (b0)
I (1840) wifi: state: auth -> assoc (0)
I (2840) wifi: state: assoc -> init (4)
I (2840) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:1
I (9270) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:1
I (9270) wifi: state: init -> auth (b0)
I (10270) wifi: state: auth -> init (2)
I (15360) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:1
I (15360) wifi: state: init -> auth (b0)
I (16360) wifi: state: auth -> init (2)
I (16780) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:1
I (16780) wifi: state: init -> auth (b0)
I (16790) wifi: state: auth -> assoc (0)
I (17790) wifi: state: assoc -> init (4)
I (17790) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:1
I (49470) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:1
I am using the latest esp-idf on Windows.
preetam
Re: WiFi not working after flashing several times Sparkfun-Thing ESP32
Postby preetam » Wed Feb 22, 2017 11:41 am
WiFi connected after 20 mins. After flashing again not connecting
mjmorrison
Postby mjmorrison » Wed Feb 22, 2017 10:42 pm
I am having a similar issue. I am flashing two dev boards with an identical sketch. One shows expected behavior, and the other shows the behavior indicated above.
kolban
Postby kolban » Thu Feb 23, 2017 12:23 am
You might want to try erasing all the flash memory in the failing devices and then flashing your application again. Stories I have seen before where the identical program runs fine in one device and fails in another have occasionally been resolved by a full flash erase.
preetam
Postby preetam » Thu Feb 23, 2017 10:08 am
Thank you for the info.
Tried erasing the flash. Flashed again after erasing. Still same issue. Changed the USB cable still same issue.
razvan_mihai
Postby razvan_mihai » Wed Aug 02, 2017 9:29 pm
Did you manage to solve the issue? Mine is facing the same problem.
In addition is getting hotter if I use the RF peripheral.
If I only blink an led , I have no problem.
I also checked the wiring. No short and all the voltages are in the expected range.
Good luck !
Users browsing this forum: Baidu [Spider] and 59 guests
