IMPORTANT: Cannot connect with WIFI
gpezzella
Postby gpezzella » Thu Sep 26, 2019 5:06 pm
this code is part of mass product device.
Chip is Wroom32 with Arduino
I have problem to connect at my home.
SSID and PASSW are correct.
Output Debug is
STATO WIFI= DISCONNECTED wait=1007
STATO WIFI= DISCONNECTED wait=9998
TIMEOUT!
SYSTEM_EVENT_STA_DISCONNECTED
Where is the problem?
What do for debug?
Please reply me because is important…
#include <WiFi.h>
#include <WiFiAP.h>
String _SSID_STA ="mySSID";
String _PASSW_STA ="MyPassword";
String _WIFI_MAC ="";
String _WIFI_IP ="";
#define TIMEOUT_WIFI_GOT_IP 10000
#define WIFI_IDLE_STATUS 0
#define WIFI_NO_SSID_AVAIL  1
#define WIFI_SCAN_COMPLETED 2
#define WIFI_CONNECTED  3
#define WIFI_CONNECT_FAILED 4
#define WIFI_CONNECTION_LOST  5
#define WIFI_DISCONNECTED 6
    delay(1000);
    Serial.println("---------------");
    Serial.println("---TEST WIFI---");
    Serial.print("SSID STA="); Serial.println(_SSID_STA);
    Serial.print("PASS STA="); Serial.println(_PASSW_STA);
    Serial.println("--------------------------");
    WiFi.mode(WIFI_MODE_STA);
    WiFi.onEvent(WiFiEvent);
    WiFi.begin(_SSID_STA.c_str() , _PASSW_STA.c_str());
    long timeout_got_ip_station=millis();
    while (WiFi.status() != WIFI_CONNECTED) {
          if ( (millis() - timeout_got_ip_station) > TIMEOUT_WIFI_GOT_IP )
              Serial.println("TIMEOUT!");
          else
              long wait= millis() - timeout_got_ip_station;
              if ( WiFi.status()== WIFI_IDLE_STATUS ) {Serial.print("STATO WIFI= IDLE    wait="); Serial.println(wait); }
              if ( WiFi.status()== WIFI_NO_SSID_AVAIL ) {Serial.print("STATO WIFI= NO SSID AVAIBLE     wait="); Serial.println(wait);}
              if ( WiFi.status()== WIFI_SCAN_COMPLETED ) {Serial.print("STATO WIFI= SCAN COMPLETE     wait="); Serial.println(wait); }
              if ( WiFi.status()== WIFI_CONNECTED ) {Serial.print("STATO WIFI= CONNECTED     wait="); Serial.println(wait); }
              if ( WiFi.status()== WIFI_CONNECT_FAILED ) {Serial.print("STATO WIFI= CONNECTION FAILED     wait="); Serial.println(wait);}
              if ( WiFi.status()== WIFI_CONNECTION_LOST ) {Serial.print("STATO WIFI= CONNECTION LOST     wait=");Serial.println(wait); }
              if ( WiFi.status()== WIFI_DISCONNECTED ) {Serial.print("STATO WIFI= DISCONNECTED     wait="); Serial.println(wait);}
}//setup
//WiFi Event
void WiFiEvent(WiFiEvent_t event){
 switch(event) {
      case SYSTEM_EVENT_STA_GOT_IP:
           Serial.println("SYSTEM_EVENT_STA_GOT_IP");
           _WIFI_MAC = (String) WiFi.macAddress();
           _WIFI_IP  = (String) WiFi.localIP().toString();
           Serial.print("WIFI MAC= ");Serial.println(_WIFI_MAC);
           Serial.print("WIFI IP= ");Serial.println(_WIFI_IP);
      case SYSTEM_EVENT_STA_DISCONNECTED:
           Serial.println("SYSTEM_EVENT_STA_DISCONNECTED");
      case SYSTEM_EVENT_WIFI_READY:
           Serial.println("SYSTEM_EVENT_WIFI_READY");
      case SYSTEM_EVENT_SCAN_DONE:
           Serial.println("SYSTEM_EVENT_SCAN_DONE");
      case SYSTEM_EVENT_STA_START:
           Serial.println("SYSTEM_EVENT_STA_START");
      case SYSTEM_EVENT_STA_STOP:
           Serial.println("SYSTEM_EVENT_STA_STOP");
      case SYSTEM_EVENT_STA_CONNECTED:
           Serial.println("SYSTEM_EVENT_STA_CONNECTED");
      case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:
           Serial.println("SYSTEM_EVENT_STA_AUTHMODE_CHANGE");
      case SYSTEM_EVENT_STA_LOST_IP:
           Serial.println("SYSTEM_EVENT_STA_LOST_IP");
      case SYSTEM_EVENT_STA_WPS_ER_SUCCESS:
      case SYSTEM_EVENT_STA_WPS_ER_FAILED:
      case SYSTEM_EVENT_STA_WPS_ER_TIMEOUT:
      case SYSTEM_EVENT_STA_WPS_ER_PIN:
      case SYSTEM_EVENT_AP_START:
      case SYSTEM_EVENT_AP_STOP:
      case SYSTEM_EVENT_AP_STADISCONNECTED:
      case SYSTEM_EVENT_AP_STACONNECTED:
      case SYSTEM_EVENT_AP_STAIPASSIGNED:
      case SYSTEM_EVENT_AP_PROBEREQRECVED:
      case SYSTEM_EVENT_GOT_IP6:
      case SYSTEM_EVENT_ETH_START:
      case SYSTEM_EVENT_ETH_STOP:
      case SYSTEM_EVENT_ETH_CONNECTED:
      case SYSTEM_EVENT_ETH_DISCONNECTED:
      case SYSTEM_EVENT_ETH_GOT_IP:
      case SYSTEM_EVENT_MAX:
Users browsing this forum: No registered users and 53 guests
