hi guys, i have a question here.
May i know the httpd transmission rate on WiFi transmission is how much, either TCP and UDP.
i'm using the FTP(file transfer protocol) on esp-idf. but the download file speed is extremely slow, below 1MB/s.
I need to transfer the chunk files in 5MB.
how much the HTTP transfer rate can archive on esp32
Re: how much the HTTP transfer rate can archive on esp32
Suggest you check the iperf example in esp-idf; that at least can tell you the ideal speed you can get in your particular situation (AP, environment, etc).
Hi both,
I've red the iperf part in details. My issue is that having this iperf code seem the only way to get decent throughput.
I am simply trying to get a file from the web from an http get. Currently I hardly reach 1mbps, which is really low.
I am not expecting 20 or 30 Mbps, but at least 5-10Mbps at a minimum.
I get:
-buffersize 1000 - delay (to fill in the buffer) 1ms Throughput : 984 kbps
-buffersize 1000 - delay (to fill in the buffer) 2ms Throughput : 480 kbps
-buffersize 2000 - delay (to fill in the buffer) 1ms Throughput : 688 kbps
-buffersize 2000 - delay (to fill in the buffer) 2ms Throughput : 384 kbps
nzh912: have you succeeded to improve your throughput?
ESP_SPRiTE: would you be able to suggest something?
I am using the below code (based on StreamHttpClient.ino) - I have played with many buffer size and delay values. I don't need the data (just trying to measure bandwidth) so I could just through it away...
I get:
#include <WiFi.h>
#include <HTTPClient.h>
bool GOTIP;
const char* ssid = "XXXXXXXX";
const char* password = "XXXXXXXX";
long speedtest(const int size) {
HTTPClient http;
const char* host = "http://ovh.net/files/10Mb.dat";
size_t count = 0;
unsigned long t_start;
unsigned long t_end;
Serial.print("connecting to "); Serial.print(host); Serial.print("\t");
Serial.println(http.begin(host));
int httpCode = http.GET();
unsigned long timeout = millis();
t_start = millis();
if (httpCode == HTTP_CODE_OK) {
int len = http.getSize();
count = len;
uint8_t buff[128] = { 0 };
WiFiClient * stream = http.getStreamPtr();
while (http.connected() && (len > 0 || len == -1)) {
size_t size = stream->available();
if (size) {
int c = stream->readBytes(buff, ((size > sizeof(buff)) ? sizeof(buff) : size));
//Serial.write(buff, c);
if (len > 0) {
len -= c;
delay(5);
t_end = millis();
Serial.print("\t\tThroughput :\t"); Serial.print(count / (t_end - t_start) * 8 ); Serial.print("\tkbps");
void setup()
Serial.print("Connecting to "); Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print("."); delay(200);
Serial.print("WiFi connected with IP:"); Serial.println(WiFi.localIP());
speedtest(2000);
void loop() {}
Sorry, I'm not familiar enough with the Arduino webserver to comment on this... Also, moving this topic to the Arduino subforum, perhaps the people there know more.
Well, if you point me to a performing esp-idf based http download code I am happy to include it in arduino.
Can anyone tell me if he has achieved a decent throughput (say >10mbps) on the esp32, on a regular file download for instance (not iperf)? On arduino, or IDF, I can adapt.
Users browsing this forum: No registered users and 65 guests
