Arduino Http component not working with ESP IDF launched WiFi
anslex
Postby anslex » Sun Sep 08, 2019 9:46 pm
Hello Everybody,
I am testing your technology and I am trying to use esp-idf with a few arduino components.
I would like to hear your advice why arduino component has no wifi connection whereas the WiFi was launched by esp-idf task in this basic exemple?
I tried to pin tasks to the same core as wifi, but without any success
esp-arduino version: 1.0.3-rc3
esp-idf version: v3.2
Here is the code or raw text below:
https://github.com/anslex/wifi_station_espidf_arduino
main.cpp
https://github.com/anslex/wifi_station_ ... n/main.cpp
#include "station.h"
#include "Arduino.h"
#include "WiFi.h"
#include <HTTPClient.h>
extern "C" void wifi_init_sta();
static void activate_wifi()
  //Initialize NVS
  ESP_ERROR_CHECK(ret);
  ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
  wifi_init_sta();
static void http_get_task(void *pvParameters)
    while(1) {
      // xEventGroupWaitBits(s_wifi_event_group, WIFI_CONNECTED_BIT,
      //                     false, true, portMAX_DELAY);
      // ESP_LOGI(TAG, "Connected to AP");
      if(WiFi.status() == WL_CONNECTED){   //Check WiFi connection status
          HTTPClient http;
          http.begin("http://jsonplaceholder.typicode.com/posts");  //Specify destination for HTTP request
          http.addHeader("Content-Type", "text/plain");             //Specify content-type header
          int httpResponseCode = http.POST("POSTING from ESP32");   //Send the actual POST request
          if(httpResponseCode>0){
           String response = http.getString();                       //Get the response to the request
           Serial.println(httpResponseCode);   //Print return code
           Serial.println(response);           //Print request answer
          }else{
           Serial.print("Error on sending POST: ");
          http.end();  //Free resources
        }else{
           Serial.println("Error in WiFi connection");
void serialSetup() {
    Serial.println("Serial.begin(115200) DONE");
    delay(10);
    Serial.println("serialSetup done");
extern "C" void app_main()
    initArduino();
    serialSetup();
    activate_wifi();
    xTaskCreate(&http_get_task, "http_get_task", 44096, NULL, 5, NULL);
station.h
https://github.com/anslex/wifi_station_ ... /station.h
/* WiFi station Example
#pragma once
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
/* The examples use WiFi configuration that you can set via 'make menuconfig'.
   If you'd rather not, just change the below entries to strings with
   the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID      CONFIG_ESP_WIFI_SSID
#define EXAMPLE_ESP_WIFI_PASS      CONFIG_ESP_WIFI_PASSWORD
#define EXAMPLE_ESP_MAXIMUM_RETRY  CONFIG_ESP_MAXIMUM_RETRY
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event, but we only care about one event
 * - are we connected to the AP with an IP? */
const int WIFI_CONNECTED_BIT = BIT0;
static const char *TAG = "wifi station";
static int s_retry_num = 0;
static esp_err_t event_handler(void *ctx, system_event_t *event);
station.c
https://github.com/anslex/wifi_station_ ... /station.c
    switch(event->event_id) {
    case SYSTEM_EVENT_STA_START:
        esp_wifi_connect();
    case SYSTEM_EVENT_STA_GOT_IP:
        ESP_LOGI(TAG, "got ip:%s",
                 ip4addr_ntoa(&event->event_info.got_ip.ip_info.ip));
        s_retry_num = 0;
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
    case SYSTEM_EVENT_STA_DISCONNECTED:
            if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
                esp_wifi_connect();
                xEventGroupClearBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
                s_retry_num++;
                ESP_LOGI(TAG,"retry to connect to the AP");
            ESP_LOGI(TAG,"connect to the AP fail\n");
    default:
    return ESP_OK;
    tcpip_adapter_init();
    s_wifi_event_group = xEventGroupCreate();
    ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL) );
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = EXAMPLE_ESP_WIFI_SSID,
            .password = EXAMPLE_ESP_WIFI_PASS
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    ESP_LOGI(TAG, "connect to ap SSID:%s password:%s",
             EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
Thank you !!!
boarchuz
Re: Arduino Http component not working with ESP IDF launched WiFi
Postby boarchuz » Mon Sep 09, 2019 7:18 am
Because you've implemented your own event handler instead. You should be using WIFI_CONNECTED_BIT of s_wifi_event_group to check WiFi connection state.
anslex
Postby anslex » Tue Oct 01, 2019 8:51 am
Thank you for your response. You are right. I noticed that it is better to stop using Arduino components, so I am rewriting some libraries in esp-idf style
Users browsing this forum: No registered users and 74 guests
