My own pcb with Arduino IDE
Hiroci
Postby Hiroci » Mon Sep 02, 2019 10:44 pm
If I design my own board with the esp32, how can I program it with the Arduino IDE
Agree007
Re: My own pcb with Arduino IDE
Postby Agree007 » Tue Sep 03, 2019 8:11 am
Assuming you pcb have the required usb port, then connect it to you pc with Arduino ide (with esp32 support setup) select the esp32 module closest to your own module, that will work unless you board are very special.
lbernstone
Postby lbernstone » Tue Sep 03, 2019 1:04 pm
If you don't intend to have a USB connector, put a 6 pin header on the board with 3V3/En/Gnd/Rx/Tx/IO0 and use an external CP2102 USB->UART adapter like https://www.aliexpress.com/item/2035365243.html
Users browsing this forum: No registered users and 55 guests
