Cant find Serial Port after download
stevewidg
Postby stevewidg » Wed Aug 14, 2019 12:55 pm
Hello
I am using Arduino IDE on Visual Studio 2019 with Visual Micro ( but same in standard IDE). I have some code which was working ok on breadboard with an old ESPdevkit I had. Ive now made some PCB and bought some new Devkit C modules. After programming the unit worked as expected, but having unplugged it, it now sees port in list, but will not connect, and gives a 'Port not Available' message.
I have checked that GPIO 0 and EN are both normally high. Also checked that GPIO1212 is LOW. I also cannot see any activity on these lines when selecting port.
I still suspect DTR/CTS but not sure how I can change them. Lots of posts say set terminal to Disable DTR/RTS but no one says how!!
Have I just been unlucky, and Ive got a dead board, or am I doing/not doing something obvious.
Help please
Steve
mikemoy
Re: Cant find Serial Port after download
Postby mikemoy » Sat Aug 17, 2019 8:01 pm
This is your own custom built PCB with your own USB serial IC onboard ?
stevewidg
Postby stevewidg » Wed Aug 21, 2019 6:26 pm
Hi Mike,
No Im using a Devkit C bought from Mouser, so hopefully the real thing. My original one was from ebay, so origin unknown Found that was cheaper than making my own.
Thanks for your interest
Steve
mikemoy
Postby mikemoy » Wed Aug 21, 2019 8:17 pm
I had the same problem with Visual Studio 2019 with Visual Micro. Back then (as I no longer use these) I switched to PlatfomIO, and never had problems since.
Users browsing this forum: No registered users and 79 guests
