I used the 'pipeline_bt_sink' example and the 'ledc' sample seperately and they work fine, but once I combine the code the fade is not there anymore. How can I solve this?
audio and rgb led
Re: audio and rgb led
i am having the same problem with some other libray to controll ws2812b strips what ledc example are you using? can you link it ?
disabling the touch peripherals has done the trick in my case
