I have several ESP32-CAM modules. One module doesn't connect to the AP when using correct credentials. Only after executing WPS it connects. That means I have to start WPS after each reset.
The same firmware works well with other modules.
The credentials are stored in the firmware, to be on the safe side.
This module has already worked properly in the past.
Q: is there any internal setting that the Wifi functions save in flash, which cause this?
What else might be the reason?
STA only connects after WPS execution
Users browsing this forum: No registered users and 177 guests
