To run some pre-certification testing, I am using ESP32_FCC_WIFI_BT_20161129.bin and ESP32_Certification_and_Test_Guide__EN.pdf.
Most of the commands described in the PDF work fine.
But I have an issue with the BT CW command "bt_tx_tone" (section 5.2.6 in the PDF document).
When I issue this command it returns "cmd not exist!"
Here is the exact syntax I use: bt_tx_tone 1 0 0
Is there an issue with my command?
Thanks & Regards,
BT certification tool bug
Re: BT certification tool bug
We are having the same problem! We are in testing now. Help!
Users browsing this forum: No registered users and 7 guests
