ESP32 I2C PCF8574 read issue
jgustavoam
Contact:
Postby jgustavoam » Mon Jul 01, 2019 3:30 am
In February 2018, I ran my sketch (arduino IDE) in my project - ESP32 digital voltmeter and it worked fine -
Arduino IDE 1.8.5 and ESP32 Board version 1.0.0.
The communication of the digital voltmeter is made with PCF8574 I2C interface. Pullups resistors are 3K3 ohms (VCC = 3.3V)
https://www.elektormagazine.com/labs/es ... /labs/1459
https://github.com/Gustavomurta/ESP32-DVM
The complete voltmeter reading data code is:
https://github.com/Gustavomurta/ESP32-D ... _PT_V1.ino
 Wire.begin();                   // Start I2C
  Wire.requestFrom(PCF8574, 1);   // Read One Byte from PCF8574
  pcfData = Wire.read();          // Byte Read
Now with Arduino 1.8.9 and ESP32 Board version 1.0.2, the I2C runs in crazy mode. The SCL pin sends continuous pulses and the SDA sends erroneous data (checked with logic analyzer).
My ESP32 is DOIT ESP32 DevKit V1 and the hardware is OK and checked with my I2C scanner. (based on Nick Gammon).
https://github.com/Gustavomurta/ESP32-D ... anner2.ino
https://github.com/Gustavomurta/ESP32-D ... 5%20V3.jpg
Researching this problem with the Debug option, I found these messages, but I do not know what it is meaning.
debugFlags=0x00000000
[I][esp32-hal-i2c.c:311] i2cDumpDqData(): Debug Buffer not Enabled
[I][esp32-hal-i2c.c:354] i2cDumpInts(): Debug Buffer not Enabled
[D][esp32-hal-i2c.c:1336] i2cProcQueue():  Busy Timeout start=0x303a4, end=0x303a4, =0, max=50 error=0
[E][esp32-hal-i2c.c:318] i2cDumpI2c(): i2c=0x3ffbebe0
[I][esp32-hal-i2c.c:319] i2cDumpI2c(): dev=0x60013000 date=0x16042000
[I][esp32-hal-i2c.c:321] i2cDumpI2c(): lock=0x3ffb84ec
[I][esp32-hal-i2c.c:323] i2cDumpI2c(): num=0
[I][esp32-hal-i2c.c:324] i2cDumpI2c(): mode=1
[I][esp32-hal-i2c.c:325] i2cDumpI2c(): stage=3
[I][esp32-hal-i2c.c:326] i2cDumpI2c(): error=0
[I][esp32-hal-i2c.c:327] i2cDumpI2c(): event=0x3ffb8570 bits=0
[I][esp32-hal-i2c.c:328] i2cDumpI2c(): intr_handle=0x3ffb85a0
[I][esp32-hal-i2c.c:329] i2cDumpI2c(): dq=0x3ffb854c
[I][esp32-hal-i2c.c:330] i2cDumpI2c(): queueCount=1
[I][esp32-hal-i2c.c:331] i2cDumpI2c(): queuePos=0
[I][esp32-hal-i2c.c:332] i2cDumpI2c(): errorByteCnt=0
[I][esp32-hal-i2c.c:333] i2cDumpI2c(): errorQueue=0
[I][esp32-hal-i2c.c:334] i2cDumpI2c(): debugFlags=0x00000000
Can someone help me? Thanks in advance.
Retired IBM Brasil
jgustavoam
Contact:
Re: ESP32 I2C PCF8574 read issue
Postby jgustavoam » Mon Jul 01, 2019 1:42 pm
I was not setting DEBUG Mode correctly !
Now setting OK .
https://github.com/espressif/arduino-es ... bugging.md
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:8424
ho 0 tail 12 room 4
load:0x40080400,len:5868
entry 0x4008069c
[D][esp32-hal-i2c.c:1337] i2cProcQueue():  Busy Timeout start=0xd5, end=0xd5, =0, max=50 error=0
[E][esp32-hal-i2c.c:319] i2cDumpI2c(): i2c=0x3ffbebe0
[I][esp32-hal-i2c.c:320] i2cDumpI2c(): dev=0x60013000 date=0x16042000
[I][esp32-hal-i2c.c:322] i2cDumpI2c(): lock=0x3ffb84ec
[I][esp32-hal-i2c.c:324] i2cDumpI2c(): num=0
[I][esp32-hal-i2c.c:325] i2cDumpI2c(): mode=1
[I][esp32-hal-i2c.c:326] i2cDumpI2c(): stage=3
[I][esp32-hal-i2c.c:327] i2cDumpI2c(): error=0
[I][esp32-hal-i2c.c:328] i2cDumpI2c(): event=0x3ffb8570 bits=0
[I][esp32-hal-i2c.c:329] i2cDumpI2c(): intr_handle=0x3ffb85a0
[I][esp32-hal-i2c.c:330] i2cDumpI2c(): dq=0x3ffb854c
[I][esp32-hal-i2c.c:331] i2cDumpI2c(): queueCount=1
[I][esp32-hal-i2c.c:332] i2cDumpI2c(): queuePos=0
[I][esp32-hal-i2c.c:333] i2cDumpI2c(): errorByteCnt=0
[I][esp32-hal-i2c.c:334] i2cDumpI2c(): errorQueue=0
[I][esp32-hal-i2c.c:335] i2cDumpI2c(): debugFlags=0x00000000
[I][esp32-hal-i2c.c:289] i2cDumpDqData(): [0] 7bit 20 R STOP buf@=0x3ffbfeb8, len=1, pos=0, ctrl=11110
[I][esp32-hal-i2c.c:307] i2cDumpDqData(): 0x0000: .                                00
[I][esp32-hal-i2c.c:347] i2cDumpInts(): 0 row	count	INTR	TX	RX	Tick
[D][esp32-hal-i2c.c:1337] i2cProcQueue():  Busy Timeout start=0x131, end=0x131, =0, max=50 error=0
[I][esp32-hal-i2c.c:289] i2cDumpDqData(): [0] 7bit 41 R STOP buf@=0x3ffbfeb8, len=1, pos=0, ctrl=11110
Retired IBM Brasil
jgustavoam
Contact:
Postby jgustavoam » Mon Jul 01, 2019 2:15 pm
I have to enable the Debug bit in the Sketch. But I have not identified the error yet.
No error is being detected.
void ReadData ()
  uint8_t flag = 1 << 1;                   // turn on bit 1
  uint32_t debugFlag = flag << 16;         // correctly position the 8bits of flag as the second byte of setBits.
  Wire.setDebugFlags(debugFlag, 0);        // resetBits=0 says leave all current setBits as is.
  Wire.setDebugFlags(0, debugFlag); // don't add any new debug, remove debugFlag
DEBUG LOG at Serial Console:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x4008069c
[D][esp32-hal-i2c.c:1337] i2cProcQueue():  Busy Timeout start=0xd6, end=0xd6, =0, max=50 error=0
[I][esp32-hal-i2c.c:335] i2cDumpI2c(): debugFlags=0x00020000
[I][esp32-hal-i2c.c:438] i2cTriggerDumps(): after ProcQueue
Retired IBM Brasil
jgustavoam
Contact:
Postby jgustavoam » Mon Jul 01, 2019 10:37 pm
Correcting important information!
I was able to do some ESP32 Voltmeter tests on my Laptop.
The Arduino IDE version is 1.8.5 and the CORE version 1.0.0.
The symptom is different, but it does not work either! Only now, Over Voltage does not appear.
The I2C interface still has a problem.
I remembered that the first version of Core I used was the previous version of 1.0.0.
And I used the old method to install the package:
Old method for installing ESP32 in the Arduino IDE:
https://github.com/espressif/arduino-es ... windows.md
I will try to recreate the environment I used when the project worked well.
Retired IBM Brasil
jgustavoam
Contact:
Postby jgustavoam » Tue Jul 02, 2019 2:27 am
Chuck (StickBreaker) helped me in Github and solved the problem!
I must change my Sketch.
https://github.com/espressif/arduino-esp32/issues/2949
Conclusion of Chuck :
Don't call Wire() from an interrupt context, Set a flag, then let the main loop do the work.
Retired IBM Brasil
Users browsing this forum: No registered users and 100 guests
