ESP32 sd card mount fail after deep sleep
Daveyman123
Postby Daveyman123 » Thu Jun 27, 2019 1:39 pm
I am getting an error that the sd card cant be mounted when the ESP32 comes out of deep sleep. The board is coded to wake up on a timer from deep sleep and mount the sd card and take a picture. My question is how can I get the SD card to mount properly? I am providing 3volts to the board and I think the same error happens when 5volts is applied. Here is the code:
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-cam-take-photo-save-microsd-card
  IMPORTANT!!!
   - Select Board "ESP32 Wrover Module"
   - Select the Partion Scheme "Huge APP (3MB No OTA)
   - GPIO 0 must be connected to GND to upload a sketch
   - After connecting GPIO 0 to GND, press the ESP32-CAM on-board RESET button to put your board in flashing mode
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include "esp_camera.h"
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "fd_forward.h"
#include "fr_forward.h"
#include "FS.h"                // SD Card ESP32
#include "SD_MMC.h"            // SD Card ESP32
#include "soc/soc.h"           // Disable brownour problems
#include "soc/rtc_cntl_reg.h"  // Disable brownour problems
#include "dl_lib.h"
#include "driver/rtc_io.h"
#include <EEPROM.h>            // read and write from flash memo
// define the number of bytes you want to access
#define EEPROM_SIZE 1
RTC_DATA_ATTR int bootCount = 0;
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
int pictureNumber = 0;
#define uS_TO_S_FACTOR 1000000
#define TIME_TO_SLEEP  60
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  Serial.setDebugOutput(true);
  //Serial.println();
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //pinMode(4, INPUT);
  //digitalWrite(4, LOW);
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  Serial.println("Starting SD Card");
  delay(2000);
  if(!SD_MMC.begin()){
    Serial.println("SD Card Mount Failed");
    //return;
  uint8_t cardType = SD_MMC.cardType();
  if(cardType == CARD_NONE){
    Serial.println("No SD Card attached");
    return;
  camera_fb_t * fb = NULL;
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    return;
  // initialize EEPROM with predefined size
  EEPROM.begin(EEPROM_SIZE);
  pictureNumber = EEPROM.read(0) + 1;
  // Path where new picture will be saved in SD Card
  String path = "/picture" + String(pictureNumber) +".jpg";
  fs::FS &fs = SD_MMC;
  Serial.printf("Picture file name: %s\n", path.c_str());
  File file = fs.open(path.c_str(), FILE_WRITE);
  if(!file){
    Serial.println("Failed to open file in writing mode");
  else {
    file.write(fb->buf, fb->len); // payload (image), payload length
    Serial.printf("Saved file to path: %s\n", path.c_str());
    EEPROM.write(0, pictureNumber);
    EEPROM.commit();
  file.close();
  delay(2000);
  // Turns off the ESP32-CAM white on-board LED (flash) connected to GPIO 4
  pinMode(4, OUTPUT);
  rtc_gpio_hold_en(GPIO_NUM_4);
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  Serial.println("Going to sleep now");
  delay(2000);
  esp_deep_sleep_start();
  Serial.println("This will never be printed");
Daveyman123
Re: ESP32 sd card mount fail after deep sleep
Postby Daveyman123 » Thu Jun 27, 2019 3:14 pm
Here is output of the error:
rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load:0x40078000,len:9232
load:0x40080400,len:6400
entry 0x400806a8
Starting SD Card
E (4147) sdmmc_sd: sdmmc_check_scr: send_scr returned 0xffffffff
No SD Card attached
ESP_igrr
Postby ESP_igrr » Thu Jun 27, 2019 4:37 pm
The code you have posted forces GPIO4 to hold its value in this line:
This pin is used for SD card interface. You need to un-hold it after deep sleep wakeup if you want to use the pin again.
Daveyman123
Postby Daveyman123 » Thu Jun 27, 2019 5:15 pm
Esp_igr
Thank you so much. This solved it for me. I should now be able to use other pins not being used by the SD card or camera? I want to add an external wake via a PIR sensor.
Daveyman123
Postby Daveyman123 » Thu Jun 27, 2019 6:31 pm
Hi igrr, I see your post on github about the ESP wrover and attaching an sd card. Could you help me a bit further and help me figure out which pin to send high or low to make an external reset possible
esp_sleep_enable_ext0_wakeup(GPIO_NUM_13,0);
I am not good with wiring but I have a transistor and some resistors and I am trying to send a signal high or low to GPIO 13. The code above makes it so the ESP knows to wake up.
here are the schematics
https://randomnerdtutorials.com/esp32-p ... nce-gpios/
and here is the pins that are used by the camera and the sd card on page 3
https://loboris.eu/ESP32/ESP32-CAM%20Pr ... cation.pdf
Daveyman123
Postby Daveyman123 » Thu Jun 27, 2019 7:40 pm
I was able to get my project to work using GPIO 13 pin D3 and a transistor and resistor to pull it down.
Users browsing this forum: Pivetta and 64 guests
