使用esp_restart()可能触发的问题
zhoupeng
Postby zhoupeng » Tue Jun 25, 2019 3:04 am
开发环境esp32-wrover-b idf:3.1-rc
现象:产品运行过程中,调用esp_restart()有几率出现,设备未发生重启,调用该函数的任务可能出现失效(推测)的现象。产品重新上电恢复正常。
目前无法复现此现象。
esp_restart()是否存在该问题隐患?
esp)restart()是否存在未重启设备,关闭开门狗后进入死循环?
[code]
void IRAM_ATTR esp_restart_noos()
    // Disable interrupts
    xt_ints_off(0xFFFFFFFF);
    // Enable RTC watchdog for 1 second
    REG_WRITE(RTC_CNTL_WDTWPROTECT_REG, RTC_CNTL_WDT_WKEY_VALUE);
    REG_WRITE(RTC_CNTL_WDTCONFIG0_REG,
            RTC_CNTL_WDT_FLASHBOOT_MOD_EN_M |
            (RTC_WDT_STG_SEL_RESET_SYSTEM << RTC_CNTL_WDT_STG0_S) |
            (RTC_WDT_STG_SEL_RESET_RTC << RTC_CNTL_WDT_STG1_S) |
            (1 << RTC_CNTL_WDT_SYS_RESET_LENGTH_S) |
            (1 << RTC_CNTL_WDT_CPU_RESET_LENGTH_S) );
    REG_WRITE(RTC_CNTL_WDTCONFIG1_REG, rtc_clk_slow_freq_get_hz() * 1);
    // Reset and stall the other CPU.
    // CPU must be reset before stalling, in case it was running a s32c1i
    // instruction. This would cause memory pool to be locked by arbiter
    // to the stalled CPU, preventing current CPU from accessing this pool.
    const uint32_t core_id = xPortGetCoreID();
    const uint32_t other_core_id = (core_id == 0) ? 1 : 0;
    esp_cpu_reset(other_core_id);
    esp_cpu_stall(other_core_id);
    // Other core is now stalled, can access DPORT registers directly
    esp_dport_access_int_abort();
    // Disable TG0/TG1 watchdogs
   [color=#FF0000] TIMERG0.wdt_wprotect=TIMG_WDT_WKEY_VALUE;
    TIMERG0.wdt_config0.en = 0;
    TIMERG0.wdt_wprotect=0;
    TIMERG1.wdt_wprotect=TIMG_WDT_WKEY_VALUE;
    TIMERG1.wdt_config0.en = 0;
    TIMERG1.wdt_wprotect=0;[/color]
    // Flush any data left in UART FIFOs
    uart_tx_wait_idle(0);
    uart_tx_wait_idle(1);
    uart_tx_wait_idle(2);
    // Disable cache
    Cache_Read_Disable(0);
    Cache_Read_Disable(1);
    // 2nd stage bootloader reconfigures SPI flash signals.
    // Reset them to the defaults expected by ROM.
    WRITE_PERI_REG(GPIO_FUNC0_IN_SEL_CFG_REG, 0x30);
    WRITE_PERI_REG(GPIO_FUNC1_IN_SEL_CFG_REG, 0x30);
    WRITE_PERI_REG(GPIO_FUNC2_IN_SEL_CFG_REG, 0x30);
    WRITE_PERI_REG(GPIO_FUNC3_IN_SEL_CFG_REG, 0x30);
    WRITE_PERI_REG(GPIO_FUNC4_IN_SEL_CFG_REG, 0x30);
    WRITE_PERI_REG(GPIO_FUNC5_IN_SEL_CFG_REG, 0x30);
    // Reset wifi/bluetooth/ethernet/sdio (bb/mac)
    DPORT_SET_PERI_REG_MASK(DPORT_CORE_RST_EN_REG,
         DPORT_BB_RST | DPORT_FE_RST | DPORT_MAC_RST |
         DPORT_BT_RST | DPORT_BTMAC_RST | DPORT_SDIO_RST |
         DPORT_SDIO_HOST_RST | DPORT_EMAC_RST | DPORT_MACPWR_RST |
         DPORT_RW_BTMAC_RST | DPORT_RW_BTLP_RST);
    DPORT_REG_WRITE(DPORT_CORE_RST_EN_REG, 0);
    // Reset timer/spi/uart
    DPORT_SET_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG,
            DPORT_TIMERS_RST | DPORT_SPI01_RST | DPORT_UART_RST);
    DPORT_REG_WRITE(DPORT_PERIP_RST_EN_REG, 0);
    // Set CPU back to XTAL source, no PLL, same as hard reset
    rtc_clk_cpu_freq_set(RTC_CPU_FREQ_XTAL);
    // Clear entry point for APP CPU
    DPORT_REG_WRITE(DPORT_APPCPU_CTRL_D_REG, 0);
    // Reset CPUs
    if (core_id == 0) {
        // Running on PRO CPU: APP CPU is stalled. Can reset both CPUs.
        esp_cpu_reset(1);
        esp_cpu_reset(0);
        // Running on APP CPU: need to reset PRO CPU and unstall it,
        // then reset APP CPU
        esp_cpu_reset(0);
        esp_cpu_unstall(0);
        esp_cpu_reset(1);
   [color=#FF0000] while(true) {
    }[/color]
[/code]
Users browsing this forum: No registered users and 51 guests
