Modify the IP address in WiFi_AP mode
JeetD27
Postby JeetD27 » Wed Jun 19, 2019 10:52 pm
I'm trying to modify the IP address in the ESP32. I'm using it in the Access Point mode over WiFi.
In the serial monitor, it's showing the IP address as '1.0.0.0' instead of the one that I have defined.
If I remove the statement, 'WiFi.softAPConfig()', then I get the default '192.168.4.1' IP address in the serial monitor.
Where am I going wrong?
The following is my code:
#include <WiFi.h>
char ssid[] = "Network-1";          //  your network SSID (name)
IPAddress IP = (10, 10, 1, 1);
IPAddress gateway = (10, 10, 1, 1);
IPAddress NMask = (255, 255, 255, 0);
WiFiServer server(80);
void setup ()
  Serial.println();
  Serial.print("System Start");
  WiFi.mode(WIFI_AP);
  WiFi.softAP(ssid);
  delay(1000);
  WiFi.softAPConfig(IP, IP, NMask);
  delay(1000);
  IPAddress myIP = WiFi.softAPIP();
  Serial.println();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.begin();
void loop ()
JeetD27
Re: Modify the IP address in WiFi_AP mode
Postby JeetD27 » Thu Jun 20, 2019 1:57 pm
I got this solved. Instead of the circular brackets for the address in the 'IP Address IP' statement, I just used curly braces. So my code remained the same, just the address was
IPAddress IP = {10, 10, 1, 1}; // curly braces
I am now getting the serial monitor to print the correct modified IP address. It actually was looking for a 'const uint16_t'
The following link might give a little info: https://github.com/espressif/arduino-es ... ress.h#L79
boarchuz
Postby boarchuz » Thu Jun 20, 2019 5:57 pm
IPAddress IP = IPAddress(10, 10, 1, 1);
JeetD27
Postby JeetD27 » Fri Jun 21, 2019 1:48 pm
Hi boarchuz,
This one works too, but I had to update the 'gateway' and 'subnet' in the same way.
IPAddress IP = IPAddress (10, 10, 2, 6); // curly braces
IPAddress gateway = IPAddress (10, 10, 2, 8); // not curly braces
IPAddress NMask = IPAddress (255, 255, 255, 0); // not curly braces
Thank You for your response.
Users browsing this forum: No registered users and 94 guests
