esp_http_client_read() returning wrong data
Pakuee
Postby Pakuee » Wed Jun 12, 2019 11:57 pm
Hi all,
I've been playing around with the esp_http_client_example, specifically the https_with_url() function. My goal is it to download a JSON file, however I've noticed some strange behaviour wenn trying to read the date from esp_http_client_read(). For small files (~100bytes) this seems to work fine, but as soon as I try to retrieve larger char arrays the output is scrambled.
For example this file will output:
Armada (@martuishere) and Javier Usobiaga (@htmlboy)
/* SITE */
        Last update:2012/02/04
        Language: Català / Czech / Deutsch / English / Castellano / Japanese / Dutch / Russian / Chinese
        Doctype:HTML5
        IDE: Sublime Text, Notepad++, FileZilla, PhotoshopTranslator: Daniel Kršiak
        Twitter: @krsiakdaniel
        ZH Translator: Ana Villalba
        JA Translator: Clémence Haure
        FR Translator: Thibaud Desodt
        Media Queries by: Marta��?humanstxt.org
Which is only the last portion of the file and also duplicated at the end. I'm not sure if the mistake is on my side in the way I retrieve the data from the function or if it is a bug.
Here is the code I used:
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "app_wifi.h"
#include "esp_http_client.h"
#define MAX_HTTP_RECV_BUFFER 512
static const char *TAG = "HTTP_CLIENT";
extern const char server_root_cert_pem_start[] asm("_binary_server_root_cert_pem_start");
extern const char server_root_cert_pem_end[]   asm("_binary_server_root_cert_pem_end");
esp_err_t _http_event_handler(esp_http_client_event_t *evt)
    switch(evt->event_id) {
        case HTTP_EVENT_ERROR:
            ESP_LOGD(TAG, "HTTP_EVENT_ERROR");
        case HTTP_EVENT_ON_CONNECTED:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_CONNECTED");
        case HTTP_EVENT_HEADER_SENT:
            ESP_LOGD(TAG, "HTTP_EVENT_HEADER_SENT");
        case HTTP_EVENT_ON_HEADER:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_HEADER, key=%s, value=%s", evt->header_key, evt->header_value);
        case HTTP_EVENT_ON_DATA:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_DATA, len=%d", evt->data_len);
            if (!esp_http_client_is_chunked_response(evt->client)) {
                // Write out data
                // printf("%.*s", evt->data_len, (char*)evt->data);
        case HTTP_EVENT_ON_FINISH:
            ESP_LOGD(TAG, "HTTP_EVENT_ON_FINISH");
        case HTTP_EVENT_DISCONNECTED:
            ESP_LOGD(TAG, "HTTP_EVENT_DISCONNECTED");
    return ESP_OK;
static void https_with_url()
    esp_http_client_config_t config = {
        .url = "http://humanstxt.org/humans.txt",
        .event_handler = _http_event_handler
    esp_err_t err = esp_http_client_perform(client);
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "HTTPS Status = %d, content_length = %d",
                esp_http_client_get_status_code(client),
                esp_http_client_get_content_length(client));
        ESP_LOGE(TAG, "Error perform http request %s", esp_err_to_name(err));
    char charbuffer[2000];
    int data_len = esp_http_client_read(client, &charbuffer, esp_http_client_get_content_length(client));
    printf("data length %i\n", data_len);
    printf("%s", charbuffer);
    esp_http_client_cleanup(client);
static void http_test_task(void *pvParameters)
    app_wifi_wait_connected();
    ESP_LOGI(TAG, "Connected to AP, begin http example");
    https_with_url();
    ESP_LOGI(TAG, "Finish http example");
    vTaskDelete(NULL);
void app_main()
    ESP_ERROR_CHECK(ret);
    app_wifi_initialise();
    xTaskCreate(&http_test_task, "http_test_task", 8192, NULL, 5, NULL);
Thank you for your time!
chegewara
Re: esp_http_client_read() returning wrong data
Postby chegewara » Thu Jun 13, 2019 4:00 pm
Probably data amount is bigger than buffer size and you have to read and concatenate data in this event:
                // Write out data
Pakuee
Postby Pakuee » Mon Jun 24, 2019 6:13 pm
I've been trying to get this to work for the past week, but I'm unable to concatenate the data between the "ON_DATA" events without the ESP crashing due to some memory allocation issue.
Do you happen to have an example that shows how to assemble the buffer properly? I've seen similar questions around other forums, but non show a concrete answer.
Thanks for your time!
pdemianczuk
Postby pdemianczuk » Wed Dec 11, 2019 8:41 am
I've similar problem, anyone knows something about that?
pdemianczuk
Postby pdemianczuk » Thu Dec 19, 2019 12:29 pm
Hi, I probably solve the problem. I update IDF to v4.1-dev-1533 from IDF4.0-dec-667. I had to update also toolchain (to esp-2019r2, compiler to 8.2.0), and I havn't problem with memory.
I found out some https://github.com/espressif/esp-idf/co ... 165cf29087
fix, but I am not sure is this fix the problem.
Generally, You should check is the component is updated.
I dunno know why, my app had a problem but the most people wasnt.
BB5000
Postby BB5000 » Fri Nov 06, 2020 3:15 pm
Hi ESPers.
About a year after the last message in this thread I happened to run into very that problem.
Sorry to say, but the above mentioned solutions were not helpful. Updating the IDF or even playing with esp_http_client_config_t parameters such as buffer_size or user_data lead to no solution.
I could however successfully solve the issue by changing over to reading the HTTP result as a stream. This actually makes a lot of sense for receiving larger results. The procedure is described in the ESP programming guide: https://docs.espressif.com/projects/esp ... lient.html
The difference is that you don't use
but rather just open it
esp_http_client_open(client, 0)
and then read from the stream in you own buffer, where of course you control the size.
If you want you can copy&paste the code from the ESP-IDF /examples/protocols/esp_http_client/main/esp_http_client_example.c in function http_perform_as_stream_reader(void)
Hope this helps someone saving some minutes and rather using them for a cup of coffee and a chat.
Bernd
Users browsing this forum: HamGuy, Heggico and 94 guests
