I use ESP32 and on one chip the program when I turn on wifi continually restarts without wifi works OK.
I've tried a stronger source for CPU, but erase Flash has not missed it?
What could it be. Also in your book I was looking for info but also samples with wifi also report this error?
Brownout detector was triggered
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:9280
load:0x40080400,len:5848
entry 0x40080698
Program:
#include <WiFi.h>
// zapnuti vystupu hodnot na serial port
// #define SERIALPRINT
// Wifi konektivita a www server
//WiFi Part
const char* ssid = "linhart_dilna";
const char* password = "xxxxxxxxxxxxx";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
//deklarace promenych
byte mb[6];
int tempRH;
float tempTep;
int anaRHout;
int tempCO2;
int anaCO2out;
int anaPWRout;
unsigned int tempPWR;
int stranka = 0;
String txt_String;
Serial.begin(115200); // start serial for output
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
delay(3000);
WiFiClient client = server.available(); // Listen for incoming clients
// if (client) { // If a new client connects,
// Serial.println("New Client."); // print a message out in the serial port
// String currentLine = ""; // make a String to hold incoming data from the client
// while (client.connected()) { // loop while the client's connected
// if (client.available()) { // if there's bytes to read from the client,
// char c = client.read(); // read a byte, then
// Serial.write(c); // print it out the serial monitor
// header += c;
// if (c == '\n') { // if the byte is a newline character
// // if the current line is blank, you got two newline characters in a row.
// // that's the end of the client HTTP request, so send a response:
// if (currentLine.length() == 0) {
// // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// // and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println("Connection: close");
client.println("Refresh: 2"); // refresh the page automatically every 2 sec
client.println();
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the table
client.println("<style>body { text-align: center; font-family: \"Trebuchet MS\", Arial;}");
client.println("table { border-collapse: collapse; width:35%; margin-left:auto; margin-right:auto; }");
client.println("th { padding: 12px; background-color: #0043af; color: white; }");
client.println("tr { border: 1px solid #ddd; padding: 12px; }");
client.println("tr:hover { background-color: #bcbcbc; }");
client.println("td { border: none; padding: 12px; }");
client.println(".sensor { color:white; font-weight: bold; background-color: #bcbcbc; padding: 1px; }");
// Web Page Heading
client.println("</style></head><body><h1>Multisensor</h1>");
client.println("<table><tr><th>Sensor</th><th>Hodnota</th></tr>");
client.println("<tr><td>Teplota: </td><td><span class=\"sensor\">");
client.println(tempTep);
client.println(" C</span></td></tr>");
client.println("<tr><td>CO2:</td><td><span class=\"sensor\">");
client.println(tempCO2);
client.println(" ppm</span></td></tr>");
client.println("<tr><td>Vlhkost:</td><td><span class=\"sensor\">");
client.println(tempRH);
client.println(" %</span></td></tr>");
client.println("<tr><td>Vykon:</td><td><span class=\"sensor\">");
client.println(tempPWR);
client.println("</body></html>");
// The HTTP response ends with another blank line
client.println();
// // Break out of the while loop
// break;
// } else { // if you got a newline, then clear currentLine
// currentLine = "";
// } else if (c != '\r') { // if you got anything else but a carriage return character,
// currentLine += c; // add it to the end of the currentLine
// // Clear the header variable
// header = "";
// // Close the connection
// client.stop();
// Serial.println("Client disconnected.");
// Serial.println("");
Continuous reboot on WiFi
Re: Continuous reboot on WiFi
Thanks for input. I am not getting the brownout message mine is TG1WDT_SYS_RESET
Then your issue is something else and I'd suggest starting your own topic, preferably with more information than just the reset reason you get.
Ooops, sorry thought this was on the post I put on Can you delete all three?
Rob
Rob
Users browsing this forum: No registered users and 43 guests
