[SOLVED] GPIO 33-35 button strange behavior. Changing value without button being pressed !
GeorgeFlorian1
Postby GeorgeFlorian1 » Wed May 08, 2019 8:28 am
Hello !
I am trying to figure out why my simple button works so randomly
This is the code that worked in the past:
#define BUTTON 34
#define PRESSED HIGH
#define NOT_PRESSED LOW
void setup {
  pinMode(BUTTON,INPUT_PULLUP);
  delay(50);
  digitalWrite(BUTTON, NOT_PRESSED);
  int q = 0;
  if (digitalRead(BUTTON) == PRESSED) {
    q++;
  delay(2000);
    q++;
void loop {}
With this code the button is either always PRESSED or NOT_PRESSED. Pressing it doesn't change its value.
With the following changes, the button behaves randomly:
#define BUTTON 34
#define PRESSED LOW
#define NOT_PRESSED HIGH
With this code the button register values on its own. On startup it can be either PRESSED LOW or NOT_PRESSED HIGH. When it starts in NOT_PRESSED HIGH it works as expected. But when it starts in PRESSED LOW I can't use it.
I've checked with the multi-meter and the button works.
This is the setup:
https://i.postimg.cc/5NMQ1y2P/20190508-115947.jpg
Last edited by GeorgeFlorian1 on Wed May 08, 2019 9:29 am, edited 2 times in total.
GeorgeFlorian1
Re: GPIO 33-35 button strange behavior. Changing value without button being pressed !
Postby GeorgeFlorian1 » Wed May 08, 2019 9:29 am
I've fixed it.
One of the libraries that I was using for the project was using GPIO 34.
Switching to GPIO 33 fixed it.
Here is the code that works now:
#define BUTTON 33
#define PRESSED LOW
void setup {
  delay(50);
  delay(50);
  int q = 0;
    q++;
  delay(2000);
    q++;
void loop {}
Users browsing this forum: No registered users and 76 guests
