MQTT example for Arduino
gpezzella
Postby gpezzella » Mon Apr 29, 2019 10:20 am
Hi
I need to publish some data on MQTT server.
I have done it using PubSubClient but it stop to work if web client is turn on ( this line in particular ESP32_Client = server.available(); )
I would ask if exist an arduino example that use IDF core library or some other good MQTT client
TomWS1
Re: MQTT example for Arduino
Postby TomWS1 » Wed May 01, 2019 3:32 pm
I have the Webserver and PubSubClient working together without any problems. I checked my code and didn't use server.available() anywhere so can't answer if that function is a problem for me. Why do you need it? I use the server.handleClient() method as it takes care of all the client gorp on its own.
Here are my web object declarations:
WebServer server(80);
WiFiClient            espClient;
PubSubClient          mqttClient(espClient);
and my initialization calls:
  server.begin();
  MDNS.addService("http", "tcp", 80);
  //  set up MQTT connection
  mqttClient.setServer(mqtt_server, 1883);
  mqttClient.setCallback(callback);
and my handler loop (in a core 0 task):
  // finally, create a loop to monitor the web & MQTT interfaces
  //  'LOOP' (Core 0)
  while (1) {
    ArduinoOTA.handle();
    server.handleClient();
    // now take care of MQTT client...
    if (!mqttClient.connected()) {
      reconnect();
    } else
      mqttClient.loop();
      // manage publications...
      if (bGotPublication) {
        char topic[80];
        sprintf(topic,"%s_out/%s",clientID,pubTopic);
        mqttClient.publish(topic,pubMsg);
        bGotPublication = false;  // signal sent
    delay(10);    // add delay so task yields...
gpezzella
Postby gpezzella » Thu May 09, 2019 11:39 am
Hi TomWS1
Now I use ESPmDNS class and it work well
Users browsing this forum: No registered users and 89 guests
