Make the type of this parameter a pointer-to-const warning when declaring a FreeRTOS task
chegewara
Re: Make the type of this parameter a pointer-to-const warning when declaring a FreeRTOS task
Postby chegewara » Mon Mar 25, 2024 8:35 pm
MicroController wrote:
Mon Mar 25, 2024 8:29 pm
To Sonar it does matter, as it tells us "Either add a parameter list or the "&" operator to this use of "HELLO_TASK"." If you have a better idea, please share.
Only when he pass function with wrong signature:
zazas321 wrote: It is still not clear to me how can I avoid this warning.
I have tried to declare my task with const void* param as shown below:
static void HELLO_TASK(const void *param)
    UNUSED(param);
    for (;;)
        printf("This is normal message1 without ANSI color code \n");
This time, I am getting another warning:
But like i said, i have no idea about SonarLint.
MicroController
Postby MicroController » Mon Mar 25, 2024 10:25 pm
Hmm. I thought that warning was already there even with the 'right' signature. If it only popped up due to the differing function pointer types, then I misunderstood.
Anyway, revising my first answer, it's better to have/disable Sonar complaining about the 'pointer-to-const' than to force a potentially incompatible function pointer type through the compiler.
zazas321
Postby zazas321 » Tue Mar 26, 2024 5:32 am
Thanks for all the suggestions.
I will also make a post to sonar community regarding this, perhaps they can shed some light as this seems to be false warning in this particular case.
As have been suggested, a correct way to declare a task is as following:
static void HELLO_TASK(void *param);
    UNUSED(param);
    for (;;)
and it should not return any warnings in this particular case. Is that correct?
Additionally, I can make the error go away if I use const void * param and also pass the address of a function to xTaskCreate. as shown below:
#include <stdio.h>
#include <inttypes.h>
#include "sdkconfig.h"
#include "freertos/task.h"
#include "esp_chip_info.h"
#include "esp_flash.h"
#include "task_monitor.h"
#include "UART0.h"
#define UNUSED(x) (void)(x)
static void HELLO_TASK(const void *param);
void app_main(void)
    printf("Hello world!\n");
    xTaskCreate(&HELLO_TASK, "HELLO_TASK", 4096, NULL, 3, NULL);
    UNUSED(param);
    for (;;)
The above will not show any errors/warnings according to SonarLint but this does not seem like an optimal solution.
Users browsing this forum: kaxx1975 and 99 guests
