Can you clarify what you mean by 'bare-metal'?
Why do you want to not 'use FreeRTOS'?
All the IDF drivers make use of FreeRTOS functionality internally. If you don't want that, you can't use the IDF drivers.
I hope my explanation is clearer this time. I intend to implement my core algorithm utilizing a state-machine bare-metal approach. Does the ESP-IDF leverage the I2C function via Interrupt Service Routines (ISRs)? Consequently, it seems superfluous to employ explicit interrupt functions.MicroController wrote: ↑Mon Dec 11, 2023 12:49 pmCan you clarify what you mean by 'bare-metal'?
i2cWrite(num, txAddress, txBuffer, txLength, _timeOutMillis);
i2cRead(num, address, rxBuffer, size, _timeOutMillis, &rxLength);
The priority doesn't really matter much here, unless you have other tasks hogging the CPU that need to be preempted when an I2C transaction is finished.If I use the Arduino IDE, at what priority should the task run? And is there any possibility to make it asynchronous?
Not sure about Arduino, but the 'bare' ESP-IDF drivers will yield the CPU while waiting for a transaction to finish; most likely the Arduino wrappers do the same, so no problem there.both take a timeout parameter, so I see no way to e.g. introduce a vTaskDelay and release control to other tasks?
See also hereWhat I want to do is to read four ADC's (Texas Instruments ADS1015) at 3.3 kHz, which is quite challenging I think?
Users browsing this forum: No registered users and 170 guests
