Downloading Firmware Question
Re: Downloading Firmware Question
You could also try `idf.py partition_table` (I think that's the right command... It's in the documentation).
Ok, I made huge jump in knowledge, but I got stuck again.
I never could get my custom board to output the startup log. I suspect that the configuration of the pins might be suppressing the logging. This could be problem later when I want more of the info, but I'll wait to figure that out later.
I realized that from within VSCode PIO I can type:
pio run -v -t upload
and I get (some output omitted):
So, now I had the location of the missing files that are the bootloader and the boot_app0.
Next, I found a Windows laptop. I installed the Espressif ESP32 Download Tool. I configured it like this:
I thought for sure that this would do the trick, but the ESP32 keeps crashing and rebooting. I also tried 80Mhz for the SPI speed but same. The one thing that I am finding that is different, is this:
Download Tool says:
while pio run -v -t upload says:
[/code]
One compresses the bootloader to 9259 bytes and the other to 9261 bytes. Is this the problem? I'm not sure where to look at this point.
"/Users/mz/.platformio/penv/bin/python" "/Users/mz/.platformio/packages/tool-esptoolpy/esptool.py" --chip esp32c3 --port "/dev/cu.usbmodem14201" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x0000 /Users/mz/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32c3/bin/bootloader_qio_80m.bin 0x8000 /Users/mz/Dropbox/PlatformIO/Projects/kinitest/.pio/build/esp32-c3-devkitm-1/partitions.bin 0xe000 /Users/mz/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin 0x10000 .pio/build/esp32-c3-devkitm-1/firmware.bin
esptool.py v3.3
Serial port /dev/cu.usbmodem14201
Connecting...
Chip is ESP32-C3 (revision 3)
Features: Wi-Fi
Crystal is 40MHz
MAC: a0:76:4e:46:14:fc
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00010000 to 0x000f1fff...
Flash params set to 0x022f
Compressed 12912 bytes to 9261...
Writing at 0x00000000... (100 %)
Wrote 12912 bytes (9261 compressed) at 0x00000000 in 0.4 seconds (effective 283.6 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 129...
Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.1 seconds (effective 340.6 kbit/s)...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 509.1 kbit/s)...
Compressed 925008 bytes to 553205...
Download Tool says:
Uploading stub...
Running stub...
Stub running...
Changed.
Compressed 12912 bytes to 9259...
is stub and send flash finish
I don't seem to have idf.py installed in the right place:
kinitest % idf.py partition_table
zsh: command not found: idf.py
If you are using a custom partition table, then you would have configured the SDK to use a csv file that you created. You should share that if that's the case. If not, then the system will use the default partition table. There are defaults for the program and nvs store as well. This is described in the ESP-IDF documentation.
As described in the documentation, here is what the default is for a single factory image (no OTA):
The default location for the partition table is 0x8000 as described in the document. In addition, the default location for the bootloader is 0x1000. This is described in the bootloader documentation. If you did not create a custom partition table and configure your ESP-IDF to use it, then the above is what it will use. Your programming using the tool needs to be consistent with that. Your partition table and app seem to be assigned the correct address, but your boot loader is not. I don't know what your boot_app0.bin is.
# ESP-IDF Partition Table
nvs, data, nvs, 0x9000, 0x6000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, factory, 0x10000, 1M,
I got over this issue but I can't really tell why it wasn't originally working.
In PlatformIO I had a setting of `board_build.partitions = min_spiffs.csv`
That would then use these files and offsets for the download to the board:
(These files seem to make sense, especially since the Download Tool includes the bootloader and the boot_app0 files in a folder along with other files. I still haven't figured out what boot_app0 does).
The problem is that when things work on my Mac, using platformio, the compressed sizes are:
When using the Download Tool on Windows:
Those 2 differing bytes seem to make a big difference.
I decided to try something else. I changed my partition settings to `board_build.partitions = no_ota.csv`, that results in a different bootloader file, but on both platforms it compressed to the same thing:
I'm still not sure what the issue was but I've managed to get my two offshore assembly teams to install my test firmware. That's success for now. I'm trying to learn more about the firmware process and the location each piece on the flash etc.
Thanks for all the help, @mbratch!! I really appreciate it.
(You use Espressif IDF and not PlatformIO, correct?)
0x0000 bootloader_qio_80m.bin
0x8000 partitions.bin
0xe000 boot_app0.bin
0x10000 firmware.bin
Compressed 12944 bytes to 9297...
Users browsing this forum: No registered users and 71 guests
