ESP32-C3 option CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG
MattiaBerton
Re: ESP32-C3 option CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG
Postby MattiaBerton » Mon Jan 03, 2022 9:58 am
I have found what was wrong, you were right: I use ESP32-c3 with visualGDB, and I need the USB JTAG/serial debug unit uses the WinUSB profile. But in this way, the COM port disappear from the Device manager. Now I have to find a way to make the WinUSB coexists with the COM port.
ESP_Sprite
Postby ESP_Sprite » Tue Jan 04, 2022 1:25 am
There is some windows trickery involved there that I don't understand, but I do know it's possible as the Windows ESP-IDF installer does that. You could try removing all drivers, then using that to install esp-idf, see if it does the right thing.
MattiaBerton
Postby MattiaBerton » Tue Jan 04, 2022 10:56 am
I've found what was wrong: the WinUSB profile is given to the root note of ESP32-C3 debug interface. If I force the WinUSB profile only on the Jtag node of the composite USB profile, I can debug and still have the COM port available.
vardas
Postby vardas » Sun Dec 17, 2023 6:02 pm
ESP_Sprite wrote:
Tue Sep 14, 2021 1:46 am
Note that current master still contains a bug where the ESP32C3 will hang on startup as long as USB is not connected or the serial port involved is not open. We're working on a fix for that.
Hi!
This is old topic but I still have this issue with esp32c3 on 4.4 (platformio still not support 5.0)
What is current state of this bug?
Users browsing this forum: Google [Bot], Majestic-12 [Bot], snutw_ and 76 guests
