Sorry for the late reply, I had notifications OFF for some reason...
Not sure you asked for photos of the assembly or photos taken by it, so here's both.
I changed the code, now I'm using Async Telegram Library which allows me to send photos in UXGA without problems.
https://github.com/FBMinis/DS3231-Alarm ... legram-Bot
Any RTC chip known to work with ESP32 cam ?
Re: Any RTC chip known to work with ESP32 cam ?
Thank you for your reply !
Actually I wanted to see a (close-up) picture of the board after your modifications.
You said that "but after removing some components I got 3uA".
Only the DS3231 chip is needed, plus two 10k pull-up resistors for SDA and SCL, and the CR2032 cell. When an alarm is set and SQW is HIGH, the P-Channel Mosfet is open and the device is off, the quiescent current is very low which allows for 5 days of a photo being sent to Telegram every 2min.
There is still much room for improvement.
Example timelapse:
https://www.youtube.com/watch?v=Bjpfm8ItYG8
https://youtu.be/A17ffdFiMxg
Example timelapse:
- photo_2021-09-29_23-29-15.jpg (157.2 KiB) Viewed 3334 times
- photo_2021-09-29_23-28-32.jpg (121.5 KiB) Viewed 3334 times
- photo_2021-09-29_23-28-08.jpg (146.47 KiB) Viewed 3334 times
Two more photos of the DS3231 module:
- photo_2021-09-29_23-29-50.jpg (123.93 KiB) Viewed 3334 times
- photo_2021-09-29_23-29-35.jpg (116.86 KiB) Viewed 3334 times
Users browsing this forum: No registered users and 38 guests
