WolfSSL ssl.h include kills WiFi event_handler
gmdriscoll
Postby gmdriscoll » Tue Jul 05, 2022 4:09 pm
I have wolf SSL installed with latest github release. Trying to get the esp-wolfssl/examples/wolfssl_client working. All of the wolfssl code has been ripped out of the example and only the wifi_init_sta and wifi_event_handler are in the code. All I am trying to do is connect to the router at this point.
When the #include "wolfssl/ssl.h" is added at the end, or anywhere in the list of includes, the wifi_event_handler hangs and does not complete by recognizing that an IP address has been found. The last notification that I get is this:
I (1511) esp_netif_handlers: sta ip: 192.168.50.17, mask: 255.255.255.0, gw: 192.168.50.1
Instead of this:
I (1511) WiFi: got ip:192.168.50.17
I (1511) WiFi: connected to ap SSID:xxxxxx password:xxxxxxx
PlatformIO and espress idf info:
PLATFORM: Espressif 32 (4.4.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-espidf @ 3.40302.0 (4.3.2)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.30300.0 (3.3.0)
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-mkfatfs @ 2.0.1
- tool-mklittlefs @ 1.203.210628 (2.3)
- tool-mkspiffs @ 2.230.0 (2.30)
- tool-ninja @ 1.9.0
- toolchain-esp32ulp @ 1.22851.191205 (2.28.51)
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
#include <string.h>
//#include <string>
#include <stdlib.h>
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/dns.h"
#include <sys/socket.h>
#include <netdb.h>
#include "lwip/apps/sntp.h"
#include "esp_netif.h"
#include <wolfssl/wolfcrypt/settings.h>
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data)
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
esp_wifi_connect();
} else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
esp_wifi_connect();
s_retry_num++;
ESP_LOGI(TAG, "retry to connect to the AP");
} else {
xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
ESP_LOGI(TAG,"connect to the AP fail");
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
s_retry_num = 0;
void wifi_init_sta(void)
s_wifi_event_group = xEventGroupCreate();
ESP_ERROR_CHECK(esp_netif_init());
ESP_ERROR_CHECK(esp_event_loop_create_default());
sta_netif = esp_netif_create_default_wifi_sta();
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
esp_event_handler_instance_t instance_any_id;
esp_event_handler_instance_t instance_got_ip;
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
ESP_EVENT_ANY_ID,
&wifi_event_handler,
NULL,
&instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
IP_EVENT_STA_GOT_IP,
NULL,
&instance_got_ip));
wifi_config_t wifi_config = {};
strcpy((char*)wifi_config.sta.ssid, "xxxxxxx");
strcpy((char*)wifi_config.sta.password, "xxxxxxx");
wifi_config.sta.threshold.authmode = WIFI_AUTH_WPA2_PSK;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
ESP_ERROR_CHECK(esp_wifi_start() );
ESP_LOGI(TAG, "wifi_init_sta finished.");
/* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
* number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
pdFALSE,
pdFALSE,
portMAX_DELAY);
/* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
* happened. */
if (bits & WIFI_CONNECTED_BIT) {
ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
} else if (bits & WIFI_FAIL_BIT) {
ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
} else {
ESP_LOGE(TAG, "UNEXPECTED EVENT");
void app_main(void)
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK(nvs_flash_erase());
/* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
* Read "Establishing Wi-Fi or Ethernet Connection" section in
* examples/protocols/README.md for more information about this function.
wifi_init_sta();
//xTaskCreate(&https_request_task, "https_request_task", 8192, NULL, 5, NULL);
Any help or idea on a direction would be very helpful.
Thanks!
Users browsing this forum: Bing [Bot], Gaston1980, Majestic-12 [Bot] and 86 guests
