I am using esp32-C3 module and external JTAG debugger ESP-Prog to debug the code. I have installed and updated the required drivers needed for JTAG interface to work using ZADIG. The openOCD is also configured during the process of installation of ESP-IDF in VS CODE.
FT2232H JTAG debugger uses Dual RS232-HS interface.
Still this error comes...
Open On-Chip Debugger v0.11.0-esp32-20211220 (2021-12-20-15:43)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
adapter speed: 5000 kHz
Info : clock speed 5000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: esp32c3.cpu: IR capture error; saw 0x00 not 0x01
Error: dtmcontrol is 0. Check JTAG connectivity/board power.
Warn : target esp32c3 examination failed
Info : starting gdb server for esp32c3 on 3333
[Stopped] : OpenOCD Server
Even tried to install Invoke-WebRequest 'https://dl.espressif.com/dl/idf-env/idf-env.exe' -OutFile .\idf-env.exe; .\idf-env.exe driver install --espressif in powershell but still no improvment.
references used:
https://docs.espressif.com/projects/esp ... -jtag.html
JTAG debugging fails
Re: JTAG debugging fails
The C3 by default uses its own internal USB-serial-JTAG controller. You need to burn an eFuse to switch that over to an external one. Alternatively, simply connect an USB cable to GPIO18/19 to make use of the internal one.
Thanks for your response
I found out this link for efuse with two options. Can you let me know which option will lead to switching over external one. and what is the procedure to configure efuse ?
I tried to connect an USB cable to GPIO18/19 but it did not worked for me.
I tried using USB-JTAG configuring it using GPIO 18/19 but my it does not get recognized .
It's in the docs. Also, you'd use espefuse.py to burn those fuses. It's odd that USB doesn't work for you; it hasn't failed yet for me; are you sure you're connecting it correctly?
Jtag debugging issues
For Jtag degugging as external one we need to strap pin GPIO10 which is not at all a strapping pin in documentation.
https://docs.espressif.com/projects/esp ... /gpio.html
C:\Users\User_name\esp\esp-idf\components\esptool_py\esptool>espefuse.py -p COM11 burn_efuse JTAG_SEL_ENABLE
I used this command for burning fuse but says invalid efuse name
USB Debugging issue
I am using a TYPE C USB connector with ESP32-C3. Connections are as follows:
TYPE C ESP32-C3
D- (A7) GPIO 18
D+ (A6) GPIO 19
V_BUS (B9) 5V
GND (B1) GND
Please find the attachment
USB Debugging issue
TYPE C ESP32-C3
D- (A7) GPIO 18
D+ (A6) GPIO 19
V_BUS (B9) 5V
GND (B1) GND
- connection USB ro Esp32-C3.jpeg (237.5 KiB) Viewed 3915 times
- JTAG OUTPUT.PNG (43.75 KiB) Viewed 3915 times
USBC may be your issue; you have the USB pins connected to only one pair of the USB lanes. Try again with the USB connector reversed.
I reversed the USB pins but it still my device does not got recognized might be breakout board issue , therefore I bought new one, now it works for me.
Thanks for your help !!!
Users browsing this forum: No registered users and 84 guests
