SSH client initialized.
Initializing TCP-IP adapter...
[OK] TCP-IP adapter initialized.
Waiting Wifi connection to "supernet"...
WiFi connected.
IP address: 192.168.178.57
Connecting to Server "192.168.178.2:22"...
SSH host connection established.
SSH session created.
Failure establishing SSH session: -125
Rebooting system now.
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5816
entry 0x400806ac
SSH Client
Re: SSH Client
I tried to use the same lib from Jose Rios and the handshake does not work as well:
Re: SSH Client
I did a little bit more debugging and change the code slightly to give some more status messages. I get to the point where Rios code says "SSH host handshake success" it fail right after that with authentication failed. But the User/PW provided do work just fine, so I did a little bit more digging into the libssh2.
It fails with error code -43 which is "BAD_SOCKET". I have also some -8 error which means handshake failed.
Rios code is very simple and does not offer any debug options, but libbsh2 has.
WiFi connected.
SSH host session handshake success.
Authentication by password failed (-43)!
Re: SSH Client
Meanwhile I have simply switched from Arduino to micropython on my ESP32 for my little project.
There is a version from Boris Lovosevic compiled for the ESP32 with a included SSH client module.
https://github.com/loboris/MicroPython_ ... o/wiki/ssh
This works very well. As I did many other projects in python anyway, there was no big deal switch to micropython.
Today I got my JTAG debug module. If I have more time this winter I may do some more digging into the code from Rios and libssh2 to see where the problem is.
Re: SSH Client
I'm a bit late to this party, but I do have an SSH client working for both the ESP8266 as well as the ESP32 using the wolfSSL libraries.
What I created is a "SSH to UART" that upon logging into the embedded SSH server, connects the user to the defined Tx/Rx pins of an externally-connected device.
For instance, here's my "SSH on a Stick" connected to an EdgeRouter-X. https://twitter.com/gojimmypi/status/15 ... 26919?s=20
My ESP32 project is here: https://github.com/gojimmypi/wolfssh/tr ... SSH-Server
My ESP8266 project is here: https://github.com/gojimmypi/wolfssh/tr ... SSH-Server
Both were developed with the VisualGDB extension for Visual Studio. The projects should build just find with the ESP-IDF (V4.4.1, not yet working with 5.x)
I'm currently working on setting up a new wolfssh-examples repo, so these examples will live here very soon:
https://github.com/wolfssl/wolfssh-examples
I have a few blog posts about wolfSSH here: https://gojimmypi.github.io/tag/wolfssh/
Users browsing this forum: username and 87 guests
