i am trying to upload and download files to the sdcard in the example. https://github.com/espressif/esp-idf/tr ... le_serving
I have activated the option "EXAMPLE_MOUNT_SD_CARD" as written in the README.
The SD card is recognized and mounted according to the log.
However, I can't find a way to access the sdcard. With the file upload button I always write to the spiffs file system in the esp.
What is the command to get to the sdcard via the url or curl?
Thanks for your help
Simple HTTP File Server Example upload/download to sdcard
Re: Simple HTTP File Server Example upload/download to sdcard
I'd also like to know how to make the v4.4 example read/write to SD card. It is mounted fine, but the file server operates on spiffs only.
Anyone listening here? I have the same problem. ESP-IDF 4.4.1 file_serving example, SD card enabled via menuconfig. Files doe not seem to be saved to SD.
Can you please try this example from latest `release/v4.4` branch? Example was fixed for SD card support in https://github.com/espressif/esp-idf/co ... fb54d1e759, this fix shall be part of v4.4.2 release.
Mahavir
https://github.com/mahavirj/
Users browsing this forum: No registered users and 63 guests
