https://docs.espressif.com/projects/esp ... lly-by-phy
Is LAN8720A suitable for this method? I read the datasheet, but I cannot see if its clock output is stopped when its reset pin is low.
Using PSRAM in ESP32 WROVER E, custom PCB.
Alternatively can anyone recommend a reliable ethernet phy that is available in 1000 qty?
LAN8720A with reset pin low - does it stop the clock?
Re: LAN8720A with reset pin low - does it stop the clock?
Unfortunately, LAN8720 does not stop CLK when in reset. Please see discussion at https://github.com/espressif/arduino-esp32/pull/6188 for more details.
Thanks, that information resulted in us going for IP101GRI to avoid this problem.
Users browsing this forum: cdollar, Google [Bot] and 91 guests
