Can I use ESP8685 based modules with ESP Rainmaker
dalohar
Postby dalohar » Tue Apr 19, 2022 4:07 am
Greetings!
As ESP8685 based modules are mentioned in ESP32-C series on https://www.espressif.com/en/products/modules, so I am curious to know whether can I use ESP8685­WROOM­06 with ESP Rainmaker framework.
If yes then what are the steps to use it?
Also can I use ESP8285 or ESP8266 Modules with ESP Rain Maker?
Regards,
Dinesh
Re: Can I use ESP8685 based modules with ESP Rainmaker
Postby ESP_Sprite » Tue Apr 19, 2022 5:44 am
Note 8685 != 8285. 8685 is C-series, 8285 is 8266-related.
dalohar
Postby dalohar » Tue Apr 19, 2022 5:48 am
As per ESP Rainmaker, ESP32 series modules are supported.
So can I use ESP8685 based modules with ESP Rainmaker.
Also as ESP8285 is ESP8266 series product, means that it can not be used with ESP Rainmaker.
Please guide.
Postby ESP_Sprite » Wed Apr 20, 2022 1:19 am
You are correct. More specifically, the ESP8685 is a variation of the ESP32-C2. Unfortunately, I don't know if Rainmaker supports that chip yet, even if it's an ESP32 variant. (Technically, there shouldn't be much hardware-wise that stops Rainmaker from working, aside from maybe memory limits.) ESP32C3 and as such should work with Rainmaker.
ESP_igrr
Postby ESP_igrr » Wed Apr 20, 2022 6:11 pm
Small correction, ESP8685 is a version of ESP32-C3.
I have written about this in more detail here: viewtopic.php?t=25384#p89869
Postby ESP_Sprite » Thu Apr 21, 2022 1:11 am
Whoops, good point. I'm confusing my ESPxxxx series once again :)
dalohar
Postby dalohar » Thu Apr 21, 2022 6:40 am
Thank you so much ESP_igrr and ESP_Sprite.
Now I will look to use ESP8685­WROOM­06 modules with ESP Rainmaker.
I hope ESP8685­WROOM­06 has price advantage over ESP32-C3-WROOM-02.
Regards,
Dinesh
baudenbacher
Postby baudenbacher » Sat Apr 30, 2022 12:38 pm
I tried the ESP32-Wroom-32E within the Arduino Platform on MacOS and the code compiles and downloads onto the platform. However, I could not connect to the device through bluetooth with the iPhone!
I also briefly tried the ESP32-C3-Wroom-02 on the Ardunio platform and with the standard config the code is too big to download.
It looks like I will be trying to install the espressif - IDE next. Having a hard time with the rainmaker. Might also need to look for something else.
Users browsing this forum: No registered users and 7 guests
