esptool load_ram
espola
esptool load_ram
Postby espola » Fri Jun 02, 2017 1:34 pm
Hi All!
Is the esptool load_ram option working?
During rf verification in production I would like to run the rf verification fw from RAM instead of flash. This would also be my preferred way of running rf verification for devices returned from customers. However if I try to use the load_ram option I get the error messages listed in the console log below.
Any help is appreciated!
Console log for esptool:
python /f/git/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 --port com25 --baud 921600 load_ram esp32_certification_and_test_en_20170602/ESP32_FCC_WIFI_BT_20170502.bin        esptool.py v2.0-beta1
Connecting......
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
WARNING: Suspicious segment 0x0, length 0
WARNING: Suspicious segment 0x40080000, length 172476
RAM boot...
  File "F:/git/nina-w1/component/cb_rtsl_esp32/esp-idf/components/esptool_py/esptool/esptool.py", line 2261, in <module>
    main()
  File "F:/git/nina-w1/component/cb_rtsl_esp32/esp-idf/components/esptool_py/esptool/esptool.py", line 2060, in main
    operation_func(esp, args)
  File "F:/git/nina-w1/component/cb_rtsl_esp32/esp-idf/components/esptool_py/esptool/esptool.py", line 1503, in load_ram
    for (offset, size, data) in image.segments:
TypeError: 'ImageSegment' object is not iterable
ESP_igrr
Re: esptool load_ram
Postby ESP_igrr » Fri Jun 02, 2017 2:36 pm
If you want to use load_ram option, make sure that the application doesn't have any sections placed into flash. Esptool points out that there is a section mapped at 0x40080000, which is the base address of memory-mapped flash region.
You can check the sections of the elf file using 'xtensa-esp32-elf-objdump -h elf_file_name'
Users browsing this forum: No registered users and 155 guests
