重新编译好的at工程,并烧录下载,发现程序一直复位
Moderator: ESP_XCGuang
fst202130609
Postby fst202130609 » Sat Mar 05, 2022 12:13 pm
[0;32mI (108) boot: End of partition table[0m
[0;32mI (112) esp_image: segment 0: paddr=00060020 vaddr=3c140020 size=2b588h (177544) map[0m
[0;32mI (159) esp_image: segment 1: paddr=0008b5b0 vaddr=3fc8f800 size=03f9ch ( 16284) load[0m
[0;32mI (163) esp_image: segment 2: paddr=0008f554 vaddr=40380000 size=00ac4h ( 2756) load[0m
[0;32mI (165) esp_image: segment 3: paddr=00090020 vaddr=42000020 size=13b67ch (1291900) map[0m
[0;32mI (452) esp_image: segment 4: paddr=001cb6a4 vaddr=40380ac4 size=0eb6ch ( 60268) load[0m
[0;32mI (466) esp_image: segment 5: paddr=001da218 vaddr=50000000 size=00004h ( 4) load[0m
[0;32mI (466) esp_image: segment 6: paddr=001da224 vaddr=50000008 size=00010h ( 16) load[0m
[0;32mI (477) boot: Loaded app from partition at offset 0x60000[0m
[0;32mI (478) boot: Disabling RNG early entropy source...[0m
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x10 (RTCWDT_RTC_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:2
load:0x3fcd6100,len:0x1730
load:0x403ce000,len:0x8e0
load:0x403d0000,len:0x295c
entry 0x403ce000
[0;32mI (31) boot: ESP-IDF v4.3-dirty 2nd stage bootloader[0m
[0;32mI (31) boot: compile time 19:46:46[0m
[0;32mI (31) boot: chip revision: 3[0m
[0;32mI (33) boot.esp32c3: SPI Speed : 40MHz[0m
[0;32mI (38) boot.esp32c3: SPI Mode : DIO[0m
[0;32mI (42) boot.esp32c3: SPI Flash Size : 4MB[0m
[0;32mI (47) boot: Enabling RNG early entropy source...[0m
[0;32mI (53) boot: Partition Table:[0m
[0;32mI (56) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (63) boot: 0 otadata OTA data 01 00 0000d000 00002000[0m
[0;32mI (71) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (78) boot: 2 nvs WiFi data 01 02 00010000 0000e000[0m
[0;32mI (86) boot: 3 at_customize unknown 40 00 0001e000 00042000[0m
[0;32mI (93) boot: 4 ota_0 OTA app 00 10 00060000 001d0000[0m
[0;32mI (101) boot: 5 ota_1 OTA app 00 11 00230000 001d0000[0m
[0;32mI (113) esp_image: segment 0: paddr=00060020 vaddr=3c140020 size=2b588h (177544) map[0m
[0;32mI (166) esp_image: segment 3: paddr=00090020 vaddr=42000020 size=13b67ch (1291900) map[0m
[0;32mI (467) esp_image: segment 5: paddr=001da218 vaddr=50000000 size=00004h ( 4) load[0m
[0;32mI (467) esp_image: segment 6: paddr=001da224 vaddr=50000008 size=00010h ( 16) load[0m
ESP_Sun
Re: 重新编译好的at工程,并烧录下载,发现程序一直复位
Postby ESP_Sun » Wed Apr 20, 2022 6:57 am
这个问题已经解决了吗?
goforit
Postby goforit » Sun Apr 24, 2022 9:28 am
我用的ESP32-C3也是这样的问题,用乐鑫发布的bin文件就没啥问题
ESP_Sun
Postby ESP_Sun » Mon Apr 25, 2022 3:27 am
可以把你的 sdkconfig 还有 build 文件夹发给我吗?我来尝试编译下
goforit
Postby goforit » Mon Apr 25, 2022 4:00 am
麻烦您了,我现在将AT所用的串口 的RX上拉电阻去掉了,复位的问题少了一些,但是我多次复位的时候也会遇到 ESP32-C3自己多次复位的问题。然后启动的时候还会提示一个错误phy_init: PHY init data failed to load。 并且编译出来的固件我使用TCP链接测试,非常的慢,还卡顿,如果我使用乐鑫的发布的BIN文件,用起来没啥问题。麻烦您了帮忙看看这个问题是什么导致的,公司目前想用ESP32-C3做图传。
esp-at.7z
(19.78 MiB) Downloaded 312 times
Users browsing this forum: No registered users and 22 guests
