Before update the project to esp32-s3 the program worked.
What can be the problem ?
esp-idf version: v5.0-dev-2485-g04bcc17dcc
Thank's.
esp_https_server: Could not allocate memory
Re: esp_https_server: Could not allocate memory
...you sure you didn't actually run out of memory?
From what i remember there was 160kB of static ram for dynamic allocation and over 7 MB of psram. I had configured in menuconfig to first try to allocate memory in psram.
Hi.
Sorry for not creating a separate thread.
I have the same error at ESP32S3. I don't know when the HTTPS server stopped working - while it was working, I was doing other things. Was debugging a new device today and got this:
Looks like it can not allocate memory for server certificates.
Certificates are presented in the same way as in the example.
Attached the log from the UART terminal to the message.
E (2288) esp_https_server: Could not allocate memory
Could you provide the full name of the option? The search returned the allocation only for the BT BLE stack.
spiram:
Try to allocate memories of wifi and lwip in spiram firstly. If failed, allocate internal memory.
mbedTLS:
Memory allocation strategy:
External spiram
mbedTLS:
External spiram
The error is because the certificate name changed from cacert to servercert.
I took the certificates from the example in esp-idf folder and put them in the certs folder of my project. I also edited the cmakelists with the new name and also changed the servercert name in my application.
now i need to know how my websocket client will be able to access the websocket server with this new certificate.
@ESP_Sprite,
Could you ask the espressif staff to look carefully at this ?
Eight months have passed.
https://github.com/espressif/esp-idf/is ... 1103254506
Thank's.
Thank's.
Users browsing this forum: Bing [Bot], Google [Bot] and 72 guests
