Invalid Header when enabling flash encryption
dovoto
Postby dovoto » Thu Mar 31, 2022 4:37 am
I am trying to enable flash encryption (without secure boot). Wrover E (16MB flash, 8MB spiram) with the aws freertos esp tool chain.
I have moved the partition table to 0xA000 and verified the system flashes and boots correctly (to make room for the bootloader).
I then did a menuconfig to set the encryption flag to build the encryption bootloader.
# Security features
# CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_SECURE_FLASH_ENC_ENABLED=y
# CONFIG_SECURE_FLASH_ENCRYPTION_MODE_DEVELOPMENT is not set
CONFIG_SECURE_FLASH_ENCRYPTION_MODE_RELEASE=y
And then do a full erase and flash of all the binaries and I get continuous invalid header and reboots
rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
invalid header: 0x5be26a30
ets Jul 29 2019 12:21:46
Am I missing a step? Do I need to set a fuse manually somewhere?
WiFive
Re: Invalid Header when enabling flash encryption
Postby WiFive » Thu Mar 31, 2022 5:09 am
What is your efuse summary?
dovoto
Postby dovoto » Thu Mar 31, 2022 5:17 am
Detecting chip type... ESP32
espefuse.py v3.0
EFUSE_NAME (Block)                       Description  = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
BLK3_PART_RESERVE (BLOCK0):              BLOCK3 partially served for ADC calibration data   = False R/W (0b0)
ADC_VREF (BLOCK0):                       Voltage reference calibration                      = 1086 R/W (0b10010)
Config fuses:
XPD_SDIO_FORCE (BLOCK0):                 Ignore MTDI pin (GPIO12) for VDD_SDIO on reset     = False R/W (0b0)
XPD_SDIO_REG (BLOCK0):                   If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset    = False R/W (0b0)
XPD_SDIO_TIEH (BLOCK0):                  If XPD_SDIO_FORCE & XPD_SDIO_REG                   = 1.8V R/W (0b0)
CLK8M_FREQ (BLOCK0):                     8MHz clock freq override                           = 56 R/W (0x38)
SPI_PAD_CONFIG_CLK (BLOCK0):             Override SD_CLK pad (GPIO6/SPICLK)                 = 0 R/W (0b00000)
SPI_PAD_CONFIG_Q (BLOCK0):               Override SD_DATA_0 pad (GPIO7/SPIQ)                = 0 R/W (0b00000)
SPI_PAD_CONFIG_D (BLOCK0):               Override SD_DATA_1 pad (GPIO8/SPID)                = 0 R/W (0b00000)
SPI_PAD_CONFIG_HD (BLOCK0):              Override SD_DATA_2 pad (GPIO9/SPIHD)               = 0 R/W (0b00000)
SPI_PAD_CONFIG_CS0 (BLOCK0):             Override SD_CMD pad (GPIO11/SPICS0)                = 0 R/W (0b00000)
DISABLE_SDIO_HOST (BLOCK0):              Disable SDIO host                                  = False R/W (0b0)
Efuse fuses:
WR_DIS (BLOCK0):                         Efuse write disable mask                           = 128 R/W (0x0080)
RD_DIS (BLOCK0):                         Efuse read disable mask                            = 1 R/W (0x1)
CODING_SCHEME (BLOCK0):                  Efuse variable block length scheme
   = NONE (BLK1-3 len=256 bits) R/W (0b00)
KEY_STATUS (BLOCK0):                     Usage of efuse block 3 (reserved)                  = False R/W (0b0)
Identity fuses:
MAC (BLOCK0):                            Factory MAC Address
   = 78:e3:6d:71:9a:6c (CRC 0x06 OK) R/W
MAC_CRC (BLOCK0):                        CRC8 for factory MAC address                       = 6 R/W (0x06)
CHIP_VER_REV1 (BLOCK0):                  Silicon Revision 1                                 = True R/W (0b1)
CHIP_VER_REV2 (BLOCK0):                  Silicon Revision 2                                 = True R/W (0b1)
CHIP_VERSION (BLOCK0):                   Reserved for future chip versions                  = 2 R/W (0b10)
CHIP_PACKAGE (BLOCK0):                   Chip package identifier                            = 1 R/W (0b001)
MAC_VERSION (BLOCK3):                    Version of the MAC field                           = 0 R/W (0x00)
Security fuses:
FLASH_CRYPT_CNT (BLOCK0):                Flash encryption mode counter                      = 0 R/W (0b0000000)
UART_DOWNLOAD_DIS (BLOCK0):              Disable UART download mode (ESP32 rev3 only)       = False R/W (0b0)
FLASH_CRYPT_CONFIG (BLOCK0):             Flash encryption config (key tweak bits)           = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE (BLOCK0):          Disable ROM BASIC interpreter fallback             = True R/W (0b1)
ABS_DONE_0 (BLOCK0):                     Secure boot V1 is enabled for bootloader image     = False R/W (0b0)
ABS_DONE_1 (BLOCK0):                     Secure boot V2 is enabled for bootloader image     = False R/W (0b0)
JTAG_DISABLE (BLOCK0):                   Disable JTAG                                       = True R/W (0b1)
DISABLE_DL_ENCRYPT (BLOCK0):             Disable flash encryption in UART bootloader        = True R/W (0b1)
DISABLE_DL_DECRYPT (BLOCK0):             Disable flash decryption in UART bootloader        = True R/W (0b1)
DISABLE_DL_CACHE (BLOCK0):               Disable flash cache in UART bootloader             = True R/W (0b1)
BLOCK1 (BLOCK1):                         Flash encryption key
BLOCK2 (BLOCK2):                         Secure boot key
   = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLOCK3 (BLOCK3):                         Variable Block 3
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V).
dovoto
Postby dovoto » Thu Mar 31, 2022 6:28 am
I should clarify that I can erase the flash and put the original firmware (with encryption not set in menu config) and it boots up and works fine.
dovoto
Postby dovoto » Thu Mar 31, 2022 5:00 pm
Update:
The problem seems to have solved itself while I slept...I dont know that I did anything differently than I was doing last night but maybe a more attentive build (moving partition table and ensuring the flash address lined up) and adding the erase flash immediately before the command to flash the binaries.
Users browsing this forum: Google [Bot] and 116 guests
