esp_http_client PSRAM use
milkolik
Postby milkolik » Tue Mar 29, 2022 1:12 am
I am planning of using the
esp_http_client
component for a project.
I started by checking out the
esp_http_client
example code but I noticed that all 4MB PSRAM of my ESP are used by
example_connect()
. Is this a quirk with this particular example code? Or does
esp_http_client
actually use all external RAM?
I plan on using some external RAM for storing some images from a camera so ideally I'd like to have some external RAM left.
Thank you!
Re: esp_http_client PSRAM use
Postby ESP_Sprite » Tue Mar 29, 2022 4:44 am
No, those examples are supposed to run even on a board without psram, so them using up a full 4MiB sounds odd. How did you measure this?
milkolik
Postby milkolik » Tue Mar 29, 2022 5:07 am
I am doing heap_caps_get_free_size(MALLOC_CAP_SPIRAM) to get the available external RAM.
I dug a bit deeper and the problem seems to be when initializing the MAC part of the w5500 ethernet module I am using.
But still not sure what is going on. I think it's a bit suspicious that after initializing I get exactly 0 bytes remaining in the external RAM. I suppose if it was going overboard it would fail while trying to allocate, right? Almost seems like it is explicitly allocating all the available external RAM but I still haven't found if this is the case.
milkolik
Postby milkolik » Tue Mar 29, 2022 5:37 am
Hmm interesting, I disabled PSRAM and it is indeed working without it!
However I do need the PSRAM for storing some images in it and currently I am unable to due to this issue. For some reason the moment I do the w5500 init the PSRAM goes to 0.
Is there a possible explanation aside of a hardware/power problem? Maybe a PIN configuration clash?
Postby ESP_Sprite » Tue Mar 29, 2022 7:36 am
Can you take a look at the startup messages; can you see the PSRAM being detected in there?
milkolik
Postby milkolik » Tue Mar 29, 2022 3:08 pm
Yes. It is detected at the beginning but nevermind, I already found the issue. The problem is that I am using pin 16 for the w5500 module and it turns out that the ESP32-CAM also uses that for PSRAM chip select!
Thank you!
Users browsing this forum: Google [Bot] and 119 guests
