esp32s3 ESP-WHO 案例测试初始化失败
烧录测试 esp-who 的案例,IDF V4.4,用到的模组是 ESP32S3 M0N8R8 开启 PSRAM 使用,出现下图错误,是怎么回事?
Re: esp32s3 ESP-WHO 案例测试初始化失败
SPI SRAM error@3d830060:aaea6ab2/aaaa6ab2
SPI SRAM error@3d830800:aaea68aa/aaaa68aa
SPI SRAM error@3d830cc0:aaea699a/aaaa699a
SPI SRAM memory test fail. 2572/262144 writes failed, first @ 3D030060
cpu_start: External RAM failed memory test! (不知怎么添加图片。。。)
你好~
建议在 menuconfig 里改为 ‘uart烧写和监听’ 看还有没有这个问题了;默认是 USB烧写和监听的
额,谢谢回复。这个程序是有正常烧录进去的,测试其他用到摄像头的example,开启 PSRAM 。现在烧录程序测试,打开monitor是停在cpu_start.c 或者不断重启
[0;33mW (273) MSPI Timing: tuning fail, best point is fallen back to index 1[0m
[0;32mI (280) spiram: Found 64MBit SPI RAM device[0m
[0;32mI (285) spiram: SPI RAM mode: sram 80m[0m
[0;32mI (289) spiram: PSRAM initialized, cache is in normal (1-core) mode.[0m
[0;32mI (296) cpu_start: Pro cpu up.[0m
[0;32mI (300) cpu_start: Starting app cpu, entry point is 0x403753d0[0m
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x2a (SPI_FAST_FLASH_BOOT)
Saved PC:0x4037599c
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x1794
load:0x403b6000,len:0xe0c
load:0x403ba000,len:0x3068
entry 0x403b626c
Build:Mar 27 2021
Saved PC:0x4037599c
SPIWP:0xee
entry 0x403b626c
Hi~ 请问是 改完 menuconfig 还是这样的错误吗?
另外 开发板用的是哪一款?
另外 开发板用的是哪一款?
你好,请问有解决了,这里也出现差不多问题
![Surprised :o](./images/smilies/icon_e_surprised.gif)
Users browsing this forum: No registered users and 12 guests
