Nimble spp_Server and client esp32c3
iamcalledusman
Postby iamcalledusman » Sat Mar 19, 2022 5:57 pm
HI
I am using Nimble spp_server and the client app. My board is esp32c3. I am successfully able to communicate the two boards . Now the issue is if I want to connect my 2nd board with spp_server then it stops connecting it . It only connects 1 board at a time.
I also configured the concurrent define parameter and as well as the BT_CTRL_BLE_MAX_ACT as shown in the attached picture. I set the value to 3 then 4 and then 8 . All the time same issue.
allrobot
Re: Nimble spp_Server and client esp32c3
Postby allrobot » Sun Mar 20, 2022 6:06 am
Check out the example file...
Use everything to search for example in the ESP-IDf folder and you might find something
iamcalledusman
Postby iamcalledusman » Sun Mar 20, 2022 12:29 pm
Thank you! for the response !
Do you mean the example folder? Yes, i used the nimble example from the example folder.
Can you please help me in this regard why unable to connect to more than 1 device? Although I tried the "Arduino-nimble example" it worked fine with multiple devices but esp-idf is not working!
Thank You!
iamcalledusman
Postby iamcalledusman » Sun Mar 20, 2022 5:45 pm
Hi Allrobot!
I have attached the pdf file for more explanation on the issue. If you could help me!
thank You!
Nimble_esp32c3_testing.pdf
(1.31 MiB) Downloaded 471 times
Users browsing this forum: Google [Bot], iotuser45, ravencarcass, Sincap and 63 guests
