Many times, I encounter errors related to either segmentation fault or one as similar to the following. I have no idea how to solve this error?
$if.py build
In file included from ../../../../components/soc/soc/esp32s2/../include/soc/rtc_io_periph.h:23,
from ../../../../components/soc/soc/esp32s2/../include/soc/rtc_periph.h:17,
from /home/ujjval/esp/esp-idf/components/soc/soc/esp32s2/rtc_periph.c:15:
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:438:9: error: macro names must be identifiers
#define �TC_CNTL_TXRF_I2C_PU_V 0x1
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:457:33: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_PLLA_FORCE_PU_S� 24
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:460:20: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_PL\A_FORCE_PD (BIT(23))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:463:24: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_PLLA_F|RCE_PD_S 23
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:469:2: error: invalid preprocessing directive #def; did you mean #ifdef?
#defne RTC_CNTL_SAR_I2C_FORCE_PU_S 22
ifdef
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:474:22: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_SAR_2C_FORCE_PD_V 0x1
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:480:28: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_GLITCH_RST<EN_V 0x1
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:486:13: warning: ISO C99 requires whitespace after the macro name
#define RTC_-NTL_I2C_RESET_POR_FORCE_PU_V 0x1
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:491:33: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_I2C_RESET_POR_F�RCE_PD_M (BIT(18))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:495:14: warning: ISO C99 requires whitespace after the macro name
#define RTC_C�TL_RESET_STATE_REG (DR_REG_RTCCNTL_BASE + 0x0038)
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:504:24: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_APPCPU{STAT_VECTOR_SEL (BIT(12))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:507:1: error: stray '\204' in program
�define RTC_CNTL_APPCPU_STAT_VECTOR_SEL_S 12
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:507:2: error: unknown type name 'define'
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:507:44: error: expected '=', ',', ';', 'asm' or '__attribute__' before numeric constant
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:513:33: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_RESET_CAUSE_APPPU_S 6
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:521:29: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_WAKEUP_STAT_REG (DR_REG_RTCCNTL_BASE + 0x003C)
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:534:13: warning: ISO C99 requires whitespace after the macro name
#define RTC_NTL_GLITCH_DET_INT_ENA_V 0x1
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:534: warning: "RTC_" redefined
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:486: note: this is the location of the previous definition
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:556:8: warning: missing terminating ' character
#define'RTC_CNTL_SWD_INT_ENA_M (BIT(15))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:556:8: error: macro names must be identifiers
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:565:40: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
.* RTC_CNTL_COCPU_INT_ENA : R/W ;bitpos:[13] ;default: 1'b0 ; */
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:565:47: error: expected identifier or '(' before 'default'
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:565:57: warning: missing terminating ' character
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:565:57: error: missing terminating ' character
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:567:18: warning: ISO C99 requires whitespace after the macro name
#define RTC_CNTL_�OCPU_INT_ENA (BIT(13))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:573:8: error: macro names must be identifiers
#define!RTC_CNTL_TSENS_INT_ENA (BIT(12))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:592:8: error: macro names must be identifiers
#define#RTC_CNTL_BROWN_OUT_INT_ENA_M (BIT(9))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:597:13: warning: ISO C99 requires whitespace after the macro name
#define RTC_�NTL_TOUCH_INACTIVE_INT_ENA (BIT(8))
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:597: warning: "RTC_" redefined
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_reg.h:534: note: this is the location of the previous definition
In file included from ../../../../components/soc/soc/esp32s2/../include/soc/rtc_io_periph.h:24,
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_struct.h:880:3: warning: data definition has no type or storage class
} rtc_cntl_dev_t;
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_struct.h:880:3: error: type defaults to 'int' in declaration of 'rtc_cntl_dev_t' [-Werror=implicit-int]
../../../../components/soc/soc/esp32s2/include/soc/rtc_cntl_struct.h:881:23: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'RTCCNTL'
extern rtc_cntl_dev_t RTCCNTL;
cc1: some warnings being treated as errors
[99/927] Building C object esp-idf/soc...es/soc_esp32s2.dir/rtc_io_periph.c.obj
FAILED: esp-idf/soc/soc/esp32s2/CMakeFiles/soc_esp32s2.dir/rtc_io_periph.c.obj
/home/ujjval/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc -Iconfig -I../../../../components/soc/soc/esp32s2/include -I../../../../components/soc/soc/esp32s2/../include -I../../../../components/soc/soc/esp32s2/private_include -I../../../../components/newlib/platform_include -I../../../../components/freertos/include -I../../../../components/freertos/xtensa/include -I../../../../components/heap/include -I../../../../components/log/include -I../../../../components/lwip/include/apps -I../../../../components/lwip/include/apps/sntp -I../../../../components/lwip/lwip/src/include -I../../../../components/lwip/port/esp32/include -I../../../../components/lwip/port/esp32/include/arch -I../../../../components/soc/src/esp32s2/. -I../../../../components/soc/src/esp32s2/include -I../../../../components/soc/include -I../../../../components/esp_rom/include -I../../../../components/esp_common/include -I../../../../components/esp_system/include -I../../../../components/xtensa/include -I../../../../components/xtensa/esp32s2/include -I../../../../components/esp32s2/include -I../../../../components/driver/include -I../../../../components/driver/esp32s2/include -I../../../../components/esp_ringbuf/include -I../../../../components/efuse/include -I../../../../components/efuse/esp32s2/include -I../../../../components/espcoredump/include -I../../../../components/esp_timer/include -I../../../../components/esp_ipc/include -I../../../../components/vfs/include -I../../../../components/esp_wifi/include -I../../../../components/esp_wifi/esp32s2/include -I../../../../components/esp_event/include -I../../../../components/esp_netif/include -I../../../../components/esp_eth/include -I../../../../components/tcpip_adapter/include -I../../../../components/app_trace/include -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.2-dirty\" -DESP_PLATFORM -MD -MT esp-idf/soc/soc/esp32s2/CMakeFiles/soc_esp32s2.dir/rtc_io_periph.c.obj -MF esp-idf/soc/soc/esp32s2/CMakeFiles/soc_esp32s2.dir/rtc_io_periph.c.obj.d -o esp-idf/soc/soc/esp32s2/CMakeFiles/soc_esp32s2.dir/rtc_io_periph.c.obj -c /home/ujjval/esp/esp-idf/components/soc/soc/esp32s2/rtc_io_periph.c
from /home/ujjval/esp/esp-idf/components/soc/soc/esp32s2/rtc_io_periph.c:15:
ifdef
} rtc_cntl_dev_t;
[101/927] Building C object esp-idf/bo...support.dir/src/bootloader_clock.c.obj
FAILED: esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock.c.obj
/home/ujjval/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -Iconfig -I../../../../components/bootloader_support/include -I../../../../components/bootloader_support/include_bootloader -I../../../../components/newlib/platform_include -I../../../../components/freertos/include -I../../../../components/freertos/xtensa/include -I../../../../components/heap/include -I../../../../components/log/include -I../../../../components/lwip/include/apps -I../../../../components/lwip/include/apps/sntp -I../../../../components/lwip/lwip/src/include -I../../../../components/lwip/port/esp32/include -I../../../../components/lwip/port/esp32/include/arch -I../../../../components/soc/src/esp32s2/. -I../../../../components/soc/src/esp32s2/include -I../../../../components/soc/include -I../../../../components/esp_rom/include -I../../../../components/esp_common/include -I../../../../components/esp_system/include -I../../../../components/xtensa/include -I../../../../components/xtensa/esp32s2/include -I../../../../components/esp32s2/include -I../../../../components/driver/include -I../../../../components/driver/esp32s2/include -I../../../../components/esp_ringbuf/include -I../../../../components/efuse/include -I../../../../components/efuse/esp32s2/include -I../../../../components/espcoredump/include -I../../../../components/esp_timer/include -I../../../../components/esp_ipc/include -I../../../../components/soc/soc/esp32s2/include -I../../../../components/soc/soc/esp32s2/../include -I../../../../components/soc/soc/esp32s2/private_include -I../../../../components/vfs/include -I../../../../components/esp_wifi/include -I../../../../components/esp_wifi/esp32s2/include -I../../../../components/esp_event/include -I../../../../components/esp_netif/include -I../../../../components/esp_eth/include -I../../../../components/tcpip_adapter/include -I../../../../components/app_trace/include -I../../../../components/spi_flash/include -I../../../../components/mbedtls/port/include -I../../../../components/mbedtls/mbedtls/include -I../../../../components/mbedtls/esp_crt_bundle/include -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.2-dirty\" -DESP_PLATFORM -MD -MT esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock.c.obj -MF esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock.c.obj.d -o esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock.c.obj -c /home/ujjval/esp/esp-idf/components/bootloader_support/src/bootloader_clock.c
In file included from /home/ujjval/esp/esp-idf/components/bootloader_support/src/bootloader_clock.c:19:
ifdef
In file included from ../../../../components/esp_rom/include/esp32s2/rom/uart.h:20,
from /home/ujjval/esp/esp-idf/components/bootloader_support/src/bootloader_clock.c:25:
../../../../components/esp_rom/include/esp32s2/rom/ets_sys.h:57:3: warning: data definition has no type or storage class
} ETS_STATUS;
../../../../components/esp_rom/include/esp32s2/rom/ets_sys.h:57:3: error: type defaults to 'int' in declaration of 'ETS_STATUS' [-Werror=implicit-int]
../../../../components/esp_rom/include/esp32s2/rom/ets_sys.h:59:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ets_status_t'
typedef ETS_STATUS ets_status_t;
../../../../components/esp_rom/include/esp32s2/rom/ets_sys.h:121:1: error: unknown type name 'ETS_STATUS'; did you mean 'EFUSE_STATE'?
ETS_STATUS ets_post(uint8_t prio, ETSSignal sig, ETSParam par);
EFUSE_STATE
[106/927] Building C object esp-idf/mb...y/CMakeFiles/mbedtls.dir/ssl_tls.c.obj
ninja failed with exit code 1
