Question to the uart_async_rxtxtasks_main.c example
NRollo
Postby NRollo » Fri Mar 04, 2022 11:09 am
In the "uart_async_rxtxtasks_main.c" UART example I came across these two lines of code:
 uart_driver_install(UART_NUM_1, RX_BUF_SIZE * 2, 0, 0, NULL, 0);
xTaskCreate(rx_task, "uart_rx_task", 1024*2, NULL, configMAX_PRIORITIES, NULL);
Why use the
*2
in these cases, is to "inform" about eg. a 16 bit data configuration?
Thanks!
Re: Question to the uart_async_rxtxtasks_main.c example
Postby ESP_Sprite » Sat Mar 05, 2022 1:30 am
I don't know why RX_BUF_SIZE * 2 is there, could be that the UART driver is storing metadata next to each received byte. The 1024*2 probably is because it's a more readable/adjustable way to say '2K of memory' than 2048.
NRollo
Postby NRollo » Sat Mar 05, 2022 10:38 am
@ESP_Sprite, thanks for the reply.
It just seemed wired to me - because later on in the code the RX buffer is allocated as:
uint8_t* data = (uint8_t*) malloc(RX_BUF_SIZE+1);
not taking into account that the driver was installed with an RX buffer of size 2048?
WiFive
Postby WiFive » Sat Mar 05, 2022 4:45 pm
Seems like it is saying we're going to process at most RX_BUF_SIZE data at once and we'll keep a ring buffer of twice that size for overhead.
NRollo
Postby NRollo » Tue Mar 08, 2022 1:46 pm
@WiFive - You are right, that could be it - make sense at least.
Thanks for chipping in.
Users browsing this forum: No registered users and 115 guests
