Setting Static IP for AP Mode not working
Pratikm78
Postby Pratikm78 » Wed Mar 02, 2022 7:28 am
I am trying to perform a wifi scan to get the available wifi networks. Then switch to AP mode to host a web page from spiffs. However require the static IP address to be set. However this is not working. Followed the documentation on netif. Please assist this seems like it should be simple
  1. void WEBCONFIG_Init()
  2. {
  3.     esp_err_t ret = nvs_flash_init();
  4.     if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
  5.     {
  6.         ESP_ERROR_CHECK(nvs_flash_erase());
  7.         ret = nvs_flash_init();
  8.     }
  9.     ESP_ERROR_CHECK(ret);
  10.     ESP_ERROR_CHECK(esp_netif_init());
  11.     ESP_ERROR_CHECK(esp_event_loop_create_default());
  12.     esp_netif_t *ap_netif = esp_netif_create_default_wifi_ap();
  13.     assert(ap_netif);
  14.
  15.
  16.     wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
  17.     ESP_ERROR_CHECK(esp_wifi_init(&cfg));
  18.     uint16_t number = 10;
  19.     wifi_ap_record_t ap_info[10];
  20.     uint16_t ap_count = 0;
  21.     memset(ap_info, 0, sizeof(ap_info));
  22.
  23.     ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
  24.     ESP_ERROR_CHECK(esp_wifi_start());
  25.     esp_wifi_scan_start(NULL, true);
  26.     ESP_ERROR_CHECK(esp_wifi_scan_get_ap_records(&number, ap_info));
  27.     ESP_ERROR_CHECK(esp_wifi_scan_get_ap_num(&ap_count));
  28.     ESP_LOGI(TAG, "Total APs scanned = %u", ap_count);
  29.     cJSON *ssidArray, *root;
  30.     root = cJSON_CreateObject();
  31.     cJSON_AddItemToObject(root, "ssid", ssidArray = cJSON_CreateArray());
  32.
  33.     for (int i = 0; (i < 10) && (i < ap_count); i++)
  34.     {
  35.         cJSON_AddStringToObject(ssidArray, "ssid", (char *)ap_info[i].ssid);
  36.     }
  37.
  38.     char *string = cJSON_PrintUnformatted(root);
  39.     printf("%s\n", string);
  40.     memset(WifiJsonBuffer, 0x00, sizeof(WifiJsonBuffer));
  41.     strcpy(WifiJsonBuffer, string);
  42.     cJSON_Delete(root);
  43.     cJSON_free(string);
  44.
  45.     esp_wifi_stop();
  46.
  47.     ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
  48.                                                         ESP_EVENT_ANY_ID,
  49.                                                         &wifi_event_handler,
  50.                                                         NULL,
  51.                                                         NULL));
  52.
  53.     wifi_config_t wifi_config = {
  54.         .ap = {
  55.             .ssid = "smart1",
  56.             .max_connection = 3,
  57.             .authmode = WIFI_AUTH_OPEN},
  58.     };
  59.     ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
  60.
  61.
  62.     ESP_ERROR_CHECK(esp_netif_dhcpc_stop(ap_netif));
  63.
  64.     esp_netif_ip_info_t ip_info;
  65.
  66.     IP4_ADDR(&ip_info.ip, 10, 0, 10, 5);
  67.     IP4_ADDR(&ip_info.gw, 10, 0, 10, 1);
  68.     IP4_ADDR(&ip_info.netmask, 255, 255, 255, 0);
  69.
  70.     ESP_ERROR_CHECK(esp_netif_set_ip_info(ap_netif, &ip_info));
  71.     ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_config));
  72.     ESP_ERROR_CHECK(esp_wifi_start());
  73. }
ESP_YJM
Re: Setting Static IP for AP Mode not working
Postby ESP_YJM » Thu Mar 03, 2022 2:21 am
Maybe you need change ESP_ERROR_CHECK(esp_netif_dhcpc_stop(ap_netif)); to ESP_ERROR_CHECK(esp_netif_dhcps_stop(ap_netif));
Pratikm78
Postby Pratikm78 » Thu Mar 03, 2022 1:47 pm
@ESP_YJM your suggestion did stop the dchp however it is not setting a static IP
ESP_YJM
Postby ESP_YJM » Fri Mar 04, 2022 6:20 am
Which error you got. Could you please describe it.
Pratikm78
Postby Pratikm78 » Fri Mar 04, 2022 9:26 am
No IP is assigned now.
  1. I (10505) wifi:new:<1,1>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
  2. I (10515) wifi:station: f8:5e:a0:df:e5:cb join, AID=1, bgn, 40U
  3. I (10515) web config: station f8:5e:a0:df:e5:cb join, AID=1
  4. I (10515) web config: starting server
  5. W (10665) wifi:<ba-add>idx:4 (ifx:1, f8:5e:a0:df:e5:cb), tid:0, ssn:9, winSize:64
  6. I (44735) wifi:station: f8:5e:a0:df:e5:cb leave, AID = 1, bss_flags is 134243, bss:0x3ffd0270
  7. I (44735) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
  8. W (44735) wifi:<ba-del>idx
  9. I (44735) web config: station f8:5e:a0:df:e5:cb leave, AID=1
ESP_YJM
Postby ESP_YJM » Fri Mar 04, 2022 12:17 pm
You can add esp_netif_dhcps_start(netif); after ESP_ERROR_CHECK(esp_netif_set_ip_info(ap_netif, &ip_info));
Users browsing this forum: jbisson and 66 guests
