Attempting installation of drivers on win10 ent x64 b19043 from offline installer fails with code -2. Log file is attached.
Perhaps there is a separate download somewhere for the drivers so I can troubleshoot in greater detail?
Thanks so much
Joe
Windows driver install fails with exit code -2
- Setup Log 2022-02-15 #008.txt
- (36.49 KiB) Downloaded 355 times
- Contact:
Re: Windows driver install fails with exit code -2
Thank you for reporting the problem.
This is definitely bug. I've created an issue to resolve it: https://github.com/espressif/idf-installer/issues/113
The installer does not support just an installation of a single driver without ESP-IDF.
There are following workarounds:
Workaround 1:
run command idf-env.exe driver install --ftdi
details: https://github.com/espressif/idf-env#qu ... powershell
Workaround 2:
install driver manually: https://github.com/espressif/idf-instal ... of-drivers
Workaround 1:
Workaround 2:
- Juraj Michálek
Senior Embedded Software Engineer at Espressif Systems
Just FYI, the issue occurs even if all other components are selected for installation.
- Contact:
Thank you for notification about the scenario. We will double-check this setup.
- Juraj Michálek
I am getting the exact same error. Is there a stable version I can use?
Users browsing this forum: Google [Bot] and 96 guests
