I designed a circuit that contains ESP32-WROOM-32D to be programmed using CP2102N-A01-GQFN28 but it didn't work and I am not able to program it
while programming, I connect GPIO0 to "PROG" (JP1) using a pin header jumper
could someone help me to find the problem?
Attached the part of my schematic that contains the programing circuit
I can't program my ESP32-WROOM-32D
- esp+cp2102n.png (65.93 KiB) Viewed 4605 times
Re: I can't program my ESP32-WROOM-32D
What happens if you manually ground IO0? If you run a terminal program on your PC on that serial port and you reset the ESP32, do you see anything?
Sorry for replying late
I didn't get anything using USB on the terminal even by connecting GPIO0 to GND directly.
I contacted the technical support of the manufacturer of CP2102 ( Siliconlabs ) and they found a mistake in the circuit of CP2102.
the circuit after being modified is attached
do you think that there is any other mistake in the circuit of ESP programing?
- cp2102n.png (76.03 KiB) Viewed 4493 times
How are you powering the ESP32? Presumably you have a regulator somewhere? Where do you derive 3.3V ?
Users browsing this forum: No registered users and 73 guests
