hi,
iam usig esp32 and esp idf 4.3 Framework .
is it possible to run using 2 task an MQTT client (port 8883) to publish data and have web page at same time .
for now each task work well separately. But i got error when i try to run both task at same code.
like :
E (385828) TRANS_TCP: tcp_poll_read select error 113, errno = Software caused connection abort, fd = 57
E (385848) MQTT_CLIENT: Poll read error: 119, aborting connection.
W (385848) httpd: httpd_accept_conn: error in accept (128).
E (395888) TRANS_TCP: [sock=54] connect() error: Host is unreachable
E (395888) MQTT_CLIENT: Error transport connect
Simultaneous MQTT and HTTP server
Re: Simultaneous MQTT and HTTP server
Yes, that should work fine (I have it working here). Can you post the code that leads to the issue?
If you can then run mqtt broker in verbose mode while you observe the problem.
IT Professional, Maker
Santiago, Dominican Republic
Memory shortage for SSL connection?
Users browsing this forum: No registered users and 73 guests
