ESP-BOX firmware wakenet_model hiesp8 does not work
Pibbotley
Postby Pibbotley » Fri Dec 24, 2021 7:47 pm
The current firmware v0.2.1 for the ESP-BOX uses wakenet_model hiesp8 which does not work. Replacing it with wakenet_model alexa8 does work.
johnlee
Re: ESP-BOX firmware wakenet_model hiesp8 does not work
Postby johnlee » Sat Dec 25, 2021 3:09 pm
could you elaborate more?
btw, it's "hi E-S-P"... for reference: https://youtu.be/n0jH1Brmee8
Pibbotley
Postby Pibbotley » Sat Dec 25, 2021 6:00 pm
See this issue https://github.com/espressif/esp-box/issues/9 for more info.
I even tried playing the video you reference to the ESP-BOX with no result.
Updating ESP-BOX using https://github.com/espressif/esp-box/tr ... ctory_demo built with the alexa wake word model and playing it this video https://www.youtube.com/watch?v=jf6G5KKGvSo works fine even when noisy.
The multinet_model also works fine.
@Shawn
Postby @Shawn » Mon Dec 27, 2021 6:43 am
Hi Pibbotley
I have checked the firmware v0.2.1 for the ESP-BOX. We can wake up by "Hi,ESP"
When I play the video https://youtu.be/n0jH1Brmee8, the ESP-BOX can not be woken up.
Can you try the attached sample to see if the sample can work.
hiesp-test.zip
(63.51 KiB) Downloaded 1688 times
Pibbotley
Postby Pibbotley » Mon Dec 27, 2021 10:59 pm
The ESP-BOX does respond to the sample you provided, and I can get the box to respond if I use my voice with a similar accent, but it is not a natural english speaking intonation.
stuartiannaylor
Postby stuartiannaylor » Mon Jan 03, 2022 2:50 am
The english hi esp firmware is very bad but someone has kindly used the alexa model and it works fine.
https://github.com/s60sc/ESP-BOX_firmware_Alexa
@Shawn
Postby @Shawn » Tue Jan 04, 2022 8:22 am
We have updated a new "Hi,ESP" model by adding more training samples.
You can pull the latest esp-sr (release/v1.0) to try it. https://github.com/espressif/esp-sr/tree/release/v1.0
Pibbotley
Postby Pibbotley » Wed Jan 05, 2022 2:43 pm
New hiesp8 model is a significant improvement
flez1966
Postby flez1966 » Fri Feb 18, 2022 6:37 pm
I have this same problem with not responding to hi ESP wake word, as it works in youtube video's its obvious the wake word model is bad or the engine code is wrong.
basically the v021 en demo is broken, a broken demo is a little embarrassing especially when shipped with it.
ESP_Rachel
Postby ESP_Rachel » Tue Mar 15, 2022 2:56 am
Kindly remind: we have updated the new application firmware, which updates the speech recognition model, add features of continuous identification, the GUI interface is compatible with current two box series development boards. You can download and experience it. https://github.com/espressif/esp-box
Users browsing this forum: No registered users and 9 guests
