Plans for experimental_cpp_component?
Are there any plans to make experimental_cpp_component a "real" component by moving it into the top-level IDF_PATH/components directory? I know we can add the existing directory to a project with EXTRA_COMPONENT_DIRS but it would be nice to have it official. In the mean time, how about adding it to the components.espressif.com registry?
Which to use, experimental_cpp_component or esp-idf-cxx?
I posted my original question about a year ago but never got a response. Since then, esp-idf-cxx was added as a standalone component but it appears to be a bit behind experimental_cpp_component. Should we start using esp-idf-cxx and can we count on it being maintained?
Re: Plans for experimental_cpp_component?
Hi gtjoseph!
Sorry for missing your post here. Yes, you should start using the esp-idf-cxx component. Actually, it shouldn't be behind the experimental_cpp_component. I will check the content is the same later. ESPEventHandlerSync has been removed because it had a design flaw that cannot be fixed without changes in the underlying esp_event component, which is not a plan or priority right now.
Eventually, we will remove the experimental_cpp_component from IDF.
Please feel free to give feedback on the esp-idf-cxx component by creating issues there or continue posting here.
Best,
Jakob
Best,
Jakob
I just checked again and in fact the experimental_cpp_component in IDF is lacking a bit behind the actual esp-idf-cxx component. As already mentioned, the experimental_cpp_component is due for removal, please use esp-idf-cxx https://github.com/espressif/esp-idf-cxx instead.
Best,
Jakob
Best,
Jakob
Thanks Jakob. I may have had my 'git diff' backwards.
The only issue right now is that esp_mqtt_cxx is built against experimental_cpp_component but I copied it out to a separate component and changed it to use esp-idf-cxx. It compiles fine but haven't had a chance to test it yet.
Users browsing this forum: Baidu [Spider], jesper and 91 guests
